3-phase plugs
Ramper
Southern MN
I have a vfd that I would like to use with two IDENTICAL Drill Presses. I need plugs to connect them. I need two males and 1 female. The output is 3 phase and I am sure under 20 amps.
R
Ramper
Southern MN
Sorry, I did not actually ask a question.
I am wondering what plug-types I should be looking for and where iis a place I can get them without breaking the bank.
theoldwizard1
SE MI
Pick your plug
R
Ramper
Southern MN
Since I want to carry a ground from the motor housing back to the VFD, it looks like NEMA 15 is the correct choice.
Vinci
I have a pair of Russellstoll 3760PDG plugs that I scavenged from a really high-end data storage array. I seriously doubt the receptacles would be cheap though.
theoldwizard1
SE MI
If you want neutral and ground you need a L21.
exmaxima
The amperage makes a huge difference in the cost of the power cord. Unless those are monster drill presses, the amperage should be more like 5 amps @ 220 vac 3P. And check if you need 4 or 5 conductor. You may not need a neutral, and 4 conductor plugs/receptacles/cords are cheaper.
Verify the power requirements before buying anything.
theoldwizard1
SE MI
We used a few L21-20 and L21-30 on some the old computers I worked on.
Yes, that old "iron" sucked that much power. Some of them had 1 hp 3 phase "air movers" (fans).
alan camby
South of Indianapolis, Indiana
Ramper,
I recomended to you a L15-30 (R and P) in a PM a week or so ago to you.
Does anyone feel this is a bad choice?
It is for 3 phase 250 volt AC with a ground and is rated for 30 amp. I see no need for a Neutral on a three phase motor. This plug is also twist lock.
3 phase plugs are expensive. Have to look around for a deal, but they still will be a lot more then single phase plugs used in the home.
alan camby
http://www.automationdirect.com/static/specs/wiringdevicesnemawiring.pdf
See page 5.
Any of the Nema plugs and receptacles on that page in the category of 3 phase, 250volt w/ ground should work for the small motors you are using. If i remember correctly they are 3/4hp. The "L" in the part # should be locking (twist lock) R is receptacle and P is plug.
15-15R, 15-20R, 15-30R, 15-50R, 15-60R, L15-20R, L15-30R
R
Ramper
Southern MN
Alan, Those were great recommendations. And I thank you for working with me. I have the vfd and temporarily installed it on one of the drills.
I was just getting other ideas. I had ordered a 3PDT but it seems WAY TOO SMALL for what I want. I will upload some pictures.
alan camby
Yeah, I understand (the switch size).
Like I said before, the correct way to switch these would be with a 3 pole relay/magnetic contactor. Could use one 3pdt or two 3pst relays. I think the two 3pst relays would be best if going the relay route. this way they would both naturally go to off when the power was off. Unlike a reversible motor starter a interlock would not be necessary.
What size wire are you using. I would use 16 MTW. If you are using THHN or a large gauge I could see the switch not working. But i have not seen the switch.
If you can't find a plug and receptacle for a good price. The relays are not going to be cheap either. At some point you might just consider buying a second VFD. This would allow a backup if a vfd failed and you could have 2 operators if you wanted at the DP.
Lots of choices :willy_nil
Good luck:)
R
Ramper
Southern MN
:willy_nil Explains me right now. I am lost with all the options. These will just be used in a small home shop by me, my wife and the kids. I want to be safe and I want it to be "legal" (not sure why) and I want it to work.
Norcal
http://garagejournal.com/forum/attachment.php?attachmentid=240759&d=1361302931[IMG][/QUOTE]
A neutral is not needed or desirable w/ the VFD the OP is intending to use.
