Best soldering iron
george4
N California
The crimping situation is taken care of. We have an SG Tool Aid Ratcheting crimper with interchangeable heads.
Been using that crimper for a few years now. Uninsulated crimp terminals with adhesive lined shrink tubing made a strong connection.
metaleltr
Western Ohio
You mean watts, I think. 100 watts will do a lot for you. I use this on most general wiring projects.
Yeah I meant watts. Wow 100 amp soldering iron, where would I even plug that in lol. I'm just not sure if 60 or 75 will be more than enough, 100w irons don't seem very popular.
metaleltr
Western Ohio
Come to think my only complaint with the crimper is that the set does not include a spark plug wire die. It and a coax crimping die are available separately though.
george4
N California
Nor does it have a die for terminals that come with the shrink tubing attached to the terminal.
metaleltr
Western Ohio
What special die does that require? I have done those successfully with a similar crimper with the die designed for insulated terminals.
MPOWERD
No and No.
Hakko is still a Japanese company, but they do have production facilities in both Japan and Malaysia (where the FX-888's were made <BTW, the FX-888 is now a discontinued model, replaced with the FX-888D>).
There are Chinese clones of the FX-888 though (did a pretty good job copying the physical appearance, but there are some missing details, such as the set screw for locking the temperature, and of course, the internals are different). Irons that come with the clones are a little easier to spot the flaws from what I've seen.
Where can I purchase one to avoid getting stuck with the Chinese knockoff?
nanofrog
The most talked about Hakko was model 936 and I have one. Check it out!
I would take Made in Japan electronic over Made in USA any day!
The 936 was a workhorse. Out of production of course, and on occasion, you might see one on eBay, but with most sellers not knowing enough, it's too easy to get a dud. And at ~$100 or perhaps a bit less, the FX-888 (left over stock at this point) or 888D can be had.
As per US made irons, there aren't that many, and the only ones I'd probably even consider, would be Pace or Metcal. Weller no longer makes irons in the US (Mexico or Germany <with Asian produced PCB's in them>).
Looking around I think I have settled on American Beauty. What amperage should I be looking at? I'm stuck between 60-75 and 100.
Not a fan of American Beauty at all.
Nor should you get hung up on the wattage. JBC's 40W irons can beat the **** out of stuff double or better due to the fact it gets the heat transfered better than the higher power competitors (why they work so well; just not cheap, but at this level, you're not looking at bargain basement stuff anyway).
I understand that a good solid crimp is typically preferred. However the harness manufacture recommended that any connections be crimped and soldered. So that is what I intend to do.
This isn't actually recommended as a general rule, as it can anneal the terminal.
There are terminals that do this, and instances that these are required, but there was a lot of engineering that went into them (i.e. pre-measured amounts of solder and flux, and the alloy composition has a lower melting point than off the shelf solder <think similar to Chip Quick>). The entire idea is that the solder cannot wick in past the insulation, and that the heat gun used (at the temp specification) is hot enough to melt the solder at the same temperature that's used for the heat shrink.
first off most people don't realize the difference in the quality of different types/manufactures of crimped terminals and as if not more important the crimping tools used.
Absolutely. :thumbup:
Good terminals are required, which means they're not the cheapest thing that can be found. It's also necessary to make sure the tooling and terminals work together properly (no over or under crimping going on).
It's similar, but it's missing the insulation crimp. The reason for this, is heat shrink tubing is not supposed to be pinched at all, so it seals properly (pinch points can leave an open gap for moisture/liquids to penetrate into the the terminal).
What you did "works", but from a technical standpoint, it qualifies as a failed crimp.
Get it from an authorized distributor or directly from HakkoUSA. Even Amazon has the real deal.
Biggest thing that will prevent you from getting a clone is stay off of eBay, aliexpress, dealextreme, ... sorts of sites. ;)
george4
N California
It is a smoother jaw like these.
http://www.sailorssolutions.com/index.asp?page=ProductDetails&Item=WP042
Seems like it would a natural die for that crimper. I tried most of the dies that come with it but they usually would put a tear in the insulation. It works fine on the hard plastic insulated terminals but I tend to stay away from those.
Steinmetz
Washington State
It all depends. I do quite a bit of antenna work outside in the winter for my ham radio stations. 100W does the trick on just about anything, even outside. If you need smaller, then fine. I have them down to about 15w, which I use on printed circuit boards.
metaleltr
Western Ohio
So do you think that a 100w would be well suited for 20 through 10+ gauge wire?
Toolhorder
Montana
I have a Hakko 936 and it's my favorite solder gun/station ever. Weller ***** in comparison.
I've used it to fix tons of vintage arcade/pinball machine PCB's and monitor PCB's when I was into that and plenty of automotive projects and what not. I bought the vacuum desolder gun to go with it too at the same time. I'm set...That was probably 4 years ago and I haven't replaced the tip yet. I use it then clean it then cover it in solder and let it cool off.
Danglerb
SoCal
All of this said however, for automotive wiring harnesses, properly performed crimps are superior to soldering (less resistance than solder, and it handles vibration better as there's an abrupt transition point between solder and wire strands). Just need the right tools, terminals, and some skill (less than is required for proper soldering).
For further information as to why this is the case, take a look at the following threads (bit of a long read, but worth it IMHO).
Solder or Crimp?
Remote starter, crimp or solder?
Totally agree, soldering has no place in an automotive wiring harness.
That said, my 35 or so year old Weller goes to the grave with me, although in that situation a butane portasol might work better. OTOH where I'm going the heat makes solder unreliable vs crimp.
Brownsfan
Cleveland Ohio
I wouldn't say it has no place. Like I said you couldn't reliably crimp the heavy gauge wires at the ignition harness when doing a remote start. You couldn't get the column shroud back on if you tried to crimp them becuase the crimp connectors would be huge. Crimp a data bus wire when installing a remote start and let me know how well it works even if its a perfect crimp. Saying it has no place is just wrong
ed_v
Kentucky
Get a Hakko 936!
I've been using Hakko soldering irons for several years now and love them. I like the 936 model. So much so that I have two of them! I do a lot of soldering. I found the Weller's to not be nearly as reliable and the heat control is not nearly as sensitive as it is on the Hakko unit.
Ed
454ragtop
Carver, MA
Interesting, I have a factory GM wire harness repair kit, part #12085264. It comes with a real nice manual, that I have sitting right in front of me, showing all the types of connectors and how they are repaired. GM says all crimped terminals should be soldered after crimping, they even include a butane soldering torch in the kit. I suspect the difference is crimps made in the field versus machine crimps in production use.
Jim
nanofrog
Jim
Less skill in the field = variable results, so they're trying to improve matters with solder.
Problem is, the copper in the terminals can end up being annealed during the soldering process as well as the solder joint-stranded wire transition causing problems (wire breakage), especially if it's wicked it's way under the wire's insulation.
As per annealing the copper, it softens/relaxes it (takes the fractures out after it's been worked awhile, and the fractures actually strengthen it, which is necessary to create a cold weld when the terminal ends are slid into one another). Thus this is more likely to create issues, such as intermittent contact over time in particular (and a royal PITA to locate the issue). Bending & breaking due to vibration is another (remember, the annealing has changed the physical behavior from what came off of the manufacturing line).
Technically possible to do without issues, but it takes a lot of skill, especially with the soldering portion (make sure the solder does not wick past the insulation, and since it's done after the crimp, it's harder to control), and keeping the terminal from getting hot enough for the right amount of time to anneal. Not worth the headache if it goes wrong IMHO, especially when a proper crimp does exactly what's needed.
Special all-in-one terminals are made for crimp, solder, and shrink, but keep in mind there was a lot of engineering that went into them. Primarily aimed at aerospace field repair, the flux and solder are pre-measured to make sure it can't wick under the insulation, and the alloy's melting point was designed to occur within the temperature the heat shrink tubing is performed.
