sds drills
koditten
Midland, Michigan
I have a SDS hammer drill that I picked up in a garage sale 15 years ago. I plugged it in and it worked, so I gave the 10 bucks being asked for it. I believe the brand is Bosch.
I have neve used this or any other hammer drill to bore holes in concrete. I have found that I need to buy a 3/4" hammer drill bit.
My question is...are these sds bits universal? I don't want to spend 30 bucks only to find out it will not work in my old drill motor.
Basicly, school me on hammer drill motors/bits.
Many thanks in advance
KIrk
MrMark
Southern Cal.
There's only one SDS Plus shank design, which must be what you are asking about. So, yes, it is universal. It's a Bosch design that is now a defacto standard.
If you have a hammer drill you don't have SDS Plus, though
SDS Plus is for a rotohammer, the SDS Plus has keyways in the side.
Justin1776
SW Florida
The most common SDS chuck design is "SDS Plus" which will cover most drilling needs for general concrete work such as tap-cons, smaller core drilling, wedge ancor holes etc. under 1 1/2" (usually) The other common SDS chuck is SDS-Max. This is for bigger chipping and demo hammers. SDS max has replaced hex drive for the most part (outside of jack hammers) For $10, I'm sure its an SDS plus
srmofo
SW ohio
google the part number and I msure something will pop up since its a well known unit.
larry_g
oregon
I actually went to the rental place and rented a bit when I needed to drill a rock for a water feature. I was able to borrow the hammer drill. Just another option. If I remember it cost a ~$10 to rent a $100+ bit.
lg
no neat sig line
Monte
Germany
SDS Plus shank looks like this
K
koditten
Midland, Michigan
The wife sent the pic as a text, not sure how to forword text pics. Anyways the drill is skil Mars 717 . Let me know what this unit uses and I will be greatfull.
WWIIjeep
Arizona
Think the skil of that era were hex shank not SDS.
Right, but the Skil 717 used a different style of hex shank bit, not the far more common 7/16" and 9/16" hex shanks used by other models of Skil roto-hammers, and most Black & Decker, Milwaukee and Rockwell rotary hammers of that era.
K
koditten
Midland, Michigan
Anyone want to buy a Skil 717?:)
Looks like I got a spare power cord for 10 bucks.
Thanks for all the effort in schooling me.
Later
KO
HAP
NE North Carolina
FYI, my Dewalt D style hammer drill accepts SDS and SDS+. You can also buy addaptors to accept the other sysles as well.
HAP
WWIIjeep
Arizona
Don't give up so fast. As KnurledNut said, ICS still sells bits for the Skil 717:
http://icscuttingtools.com/catalog/page_157.pdf
(Second listing on the page for Skil 717, not the B&D 717 at the top.)
Assuming you really want to have your own rotohammer instead of just renting when needed, or spending $300 on a new one and the price of bits on top of that.
The old Skil rotohammers were excellent heavy-duty tools and well-respected. The only reason they're not still making them is because when Bosch and Skil merged in 1992 (before complete ownership by Bosch in 1996), the competing industrial-quality products in the Skil line were discontinued.
minimowog
Gloucester UK
here's my B&D hammer drill, made in the USA, hex shaft, comes in a suit case
and a bosch sds plus, with interchangable chuck
