ajchien
Hi folks, I'm sorry to be somewhat vague about this question and application, but if someone could school me or refer me somewhere for more info that would be great.
I've currently got a drill bit that has an eccentric tip. This is so that the drill purposely wobbles and the hole cut is larger than the drill bit itself, to allow a metal tube (sheath) to slide down along the side, surrounding the drill bit as it cuts deeper. Currently the flutes are only about 1cm in length and the shank is about 10cm long.
The drill has to penetrate through 7cm of soft material - without damaging the soft material (hence the Outer metal sheath). But then where i need to Cut, I'm cutting through pretty hard material- not quite as hard as steel, but much harder than hardwood. The depth of the hole cut only needs to be at most 5-6mm.
So the current problem is that I often need to withdraw the drill bit from the protective sheath because the flutes get filled up with the chips. I don't want to have to remove the drill to remove chips and to keep drilling longer. Is this accomplished by making the flutes longer? Wider? Should there be channels cut in them similar to taps to accommodate the chips?
Ok. Sorry for being so vague. Thanks for any thoughts.
