Jeeper
A few months back my 4 ton Craftsman Pro stopped working. The jack started it's malfunctioning when sometimes it wouldn't lift all the way, then it wouldn't left anything up. I bought a new Arcan from Costco and the old CM has just been sitting there. Saw HiBall's tutorial come up again, so I thought I'd rip into it.
Here are some pictures. I got it torn down. I think it's the cup seal as there are some scratches on it. I did take apart the valves but i marked them and counted the threads so they should be the same and already reinstalled. I took them out to check the seals.
The seal looks like it's a 24x40x10mm. Hopefully Hiball has one. This is part of an experiment and part if i can get it to work it will be good to have an extra jack in the garage. Plus I hate throwing it away for a cheap seal.
Removed the power unit:
Removing the tank nut. Luckily my friend texasspartan bought the 55mm beta socket when it was cheap.
Ram is out:
I would love to know what each of the screws do. I have pictures of what's underneath each cap.
The seals on the ram:
The grooves in the seal:
Ram is out:
I Think sometimes you just want to disagree with me and then in the End you come around to my way of thinking, It just takes you awhile to get there.
