brianstrange
- Joined
- Mar 24, 2013
- Messages
- 18
Hello, newbie here, with another floor jack question / issue.
I found this site thru Hiball's post on overseas jack repair, and I'm hoping someone can help.
I have a Craftsman model 9-50167 4 ton floor jack (same as Torin "Big Red" model T84004.) I purchased the rebuild kit from them, and in the process of rebuilding it, I'm now questioning if I lost something. There are four screws on the top of the unit.
1) "Do not adjust"
2) Large phillips head
3&4) similar adjustment ports of some sort. - this is where my question leeds to.
In the pictures, you can see that one of these has a spring with a small ball at the end, and the other just has a ball (no spring to hold the ball tight)
Although I was careful and swear that I didn't lose anything, I was hoping someone with experience could offer some knowledge on this jack, and tell me if this is correct.
NOTE: This is a fast lift with a second small cylinder.
The first & second pic match screws to ports.
Thank you,
Brian
1) "Do not adjust"
Thank you,
Brian
