Hello all, i'm a fairly new member and just finished a big chunk of my garage and thought I would share it with you all. I'm located in sunny Arizona and own a 3 car garage. We have a large craigslist scene here in AZ and I got lucky and scored around 1,000 sq ft of used True Lock Plus Premium Rib Drain Garage Tiles from a local seller for $500. I had more than enough to do my 3 car garage and a portion along the side of my house. I also just had a new custom work bench installed to match the previous cabinets i had installed. THE color is espresso. My walls are painted a slight silver with a hint of blue tint called silver screen, it's used a lot for walls that are used for projectors without a screen. I have a 5.1 surround system wired up in the garage as well. The last few parts I need to finish my garage would be additional lighting (not sure which direction to go there yet) and also a new 32-40" tv and then I should be done. So far i'm very happy with the tiles. I need to give them a good cleaning since they were used and then they should look as good as new.
Enjoy!
Enjoy!
