IONH
I think it's the tires like skulldrinker said....
Strange, no noticeable odor for mine.
How often DID you put air tool oil in it?FAIL.
1/2" Reversible Air Drill
Central Pneumatic - item#98896
http://www.harborfreight.com/1-2-half-inch-reversible-air-drill-98896.html
About 6 months old used it only 2-3 times and the chuck froze up solid. I had the warranty so i got a free replacement. I don't know what will happen with this one. Maybe I will oil it more often. I had gotten this drill on a quick purchase when i landed a job and had to buy many tools and a box all at once. I'd like to save up for a better one next time like in the $80-$90 range.
What? You mean I'm not supposed to just rub it around on the outside?
Coach
Every time just like i'm suppose to. On the very first use i recall after about a half hour of drilling the RPM's noticeably dropped. I added more oil and it speed up to normal for a while but I knew it was going to be toast. Then this last time I oiled it up at first and was about 10 min into drilling out a wheel stud and it froze up. Good thing I had my electric drill nearby so i could finish the job.
PS I don't want you to think I drilled for 30 min without re-oiling it. I did add oil occasionally.
PSS The first time was Marvel air tool oil and when it froze up totally I was using HF air tool oil. Just a coincidence probably.
air tools are very simple, pull it apart and do an autopsy. see what broke.
there are multiple times where someone wanted to throw out an air tool cause it stopped working, and i bought it for cheap, then threw in a new set of vanes for 2 bucks and got a new air tool out of it
Me too ^ waiting on a 349 coupon to pop up
I paid $19 for it. Plus $5 for the warranty. Got a free replacement.
Where would a person begin to search for parts for a $19 drill?
Snap Ring Pliers with Interchangeable Heads - EPIC FAIL (just a terrible snap ring pliers)
http://www.harborfreight.com/snap-ring-pliers-with-interchangeable-heads-3316.html
Originally Posted by Nicky9:
3 HP, 21 Gallon, 125 PSI Cast Iron Vertical Air Compressor FAIL
Just bought one of these (94667 compressor) and there is a pinhole in the top weld.
I could hear the air leaking and found it right away.
FAIL I guess, although I haven't actually used it yet.
I will exchange it.
http://www.harborfreight.com/3-hp-21-gallon-115-psi-cast-iron-vertical-air-compressor-94667.html
I picked up a 6 piece set of the 7 Piece 1/2" Drive Metric Impact Swivel Socket Set...They had them marked down because the the 13MM was missing...Normally $29, I got them for $13, in the clearance rack.... I think I did good for less the $2.25 each...
http://www.harborfreight.com/7-piece-12-drive-metric-impact-swivel-socket-set-67911.html
I picked up a HF engine support bar, item number 96524, http://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html. I was replacing some motor mounts and was supporting the engine/trans with a couple floor jacks with wood between the jack and engine. I ran into a problem with a broken bolt and ran out of time so ran to HF quick and bought one of these for 60 bucks, 75 minus 20%. I know they go on sale for cheaper but I needed one now. I have to give HF credit because I live in a decent sized town with all major auto parts stores and two farm supply stores and a handful of big box stores amongst many other hardware and other stores and the only place I could get one of these right now is HF. So if nothing else they got my business because they are the only store that has specialty stuff in stock when you need it. The quality feels very good. Heavy duty and ended up not getting back to the car all weekend and it did just fine holding the engine up over the weekend. I thought about making one of these but by the time I made it and the hardware and made it as nice as the HF one it would have cost me 60 bucks. I will probably replace the chains with some good quality ones. The nice thing about this is I can roll around all under the car working on it without a floor jack in my way. I've always just used a floor jack to support the engine when needed but then it was in the way working under the car. With this above engine support the whole under side of engine is clear to work on. The only thing I might change is the addition of a 3rd leg which I might do sometime just to make it a little more user friendly on some engines.
I give it a big pass, especially for the money.
Thanks for the review I have one also. Bought it when I thought I was going to need it but ended up not using it. I also felt less than perfect with it not having the 3rd arm. Please post any pictures of your improvements to yours if you make any. Or any info to any 3rd arm plans that can used to make the modification.
---cut---http://www.toolking.com/omega-44700-700-pound-engine-support-bar. If you click on the picture to blow it up it shows the adjustable leg. I think the main thing is making sure everything is adjustable to make sure it's supported just right.---cut---
That looks like mine ... and it works fine. I got mine at Princess Auto though.looking for a pass or fail verdict on this floor jack.
Compact Aluminum Racing Floor Jack With Rapid Pump®, 1.5 Tons
Pittsburgh Automotive
- Item#68053
- Item#68053
- Item#68053
- Item#68053
I also have that jack. I used it quite a bit. I say it is a pass. I like it because it is so light. I can take it anywhere. There is also a beefier version of the 1.5 tons, but cost a little more.
light....??? you have a different one then.
that jack which comes in any number of other rebadge version is "compact" not "lightweight". it weighs a ton compared to an all aluminum version. but i stay away from the cheap aluminum build ones as the last one i had, had the swivel at the bottom of the handle just disconnect completely and fall apart while the car was in the air.... getting that down without dropping the car hard was a toughy, and just go for heavier construction jacks now.
I am pretty sure that is an aluminum jack. At least mine is aluminum.
