I just pulled the trigger on a plasma cutter
Joe69
Muncie, Indiana
After buying my new Tig welder in January, I've had the itch for a plasma cutter. Miller has a 15% rebate until the end of March, so I went for it. It's a 625 x-treme. Capable of cutting up to 5/8 steel, and will run on 120v & 240v. I went ahead and got the circle cutter guide, and a consumable kit too.
I can't wait to try it out, I haven't used one in several years.
Joe
Hghgrad
Detroit MI
You'll love having it around. I stopped trying to take off any nut/bolt that even looks like its going to give me trouble on the car. Now, I just grab the plasma and buzz it off :)
madosta
I thought it ran until the end of May?
Guess I'm going to go to my LWS tomorrow. I'm thinking about building a CNC plasma cutter should be a good one to get me started.
R6 Racer
Northern Ontario Canada
Great looking outfit! Congrats!!
Myself being a fan of the red machines. I just wanted to ask if you did a comparison between the 2, and if you did what made you pick the miller. I'm not opposed to the blue stuff & I was just curious.
Steve
Murphy4570
West Deptford NJ
Aw man that is a bad *** plasma cutter. I would love to have one of those, or a Lincoln one.
Don't let the Hypertherm fanboy get you down, Miller makes top-notch products.
affende
behind the welding hood
FWIW .... i have two hypertherm plasma cutters in my shop .... they are holding up the cobwebs in the corner.
but wait ... Ford is better than Chevy which is better than Dodge ... or is it the other way around?
you know what they say about opinions ...
everyone has a preference ... and everyone is wrong.
koditten
Midland, Michigan
I can't even rember which one I got. Miller 675 hypotherm? I don't know or don't care. It works like it is supposed to. You will love having a plasma cutter. Thanks for sharing.
Later
KO
gte718p
I love my plasma. I'll admit I've pulled it out less in the last couple of weeks after I discovered the metal cuttiing circular saw. Plasma opens up so many possibilities and makes cutting ridiculously easy.
MarkG
Elgin, IL
Cool! Wish I had a good excuse to get one. :S I don't know much about them other than 'YouTube vid knowledge', so excuse my ignorance, but what are the air requirements for a cutter like that? (How big of a compressor is recommended, minimum?) Thanks. Have fun with that!
thenephilm
cincinnati
I bought my miller last november from zorotools.com...works great, haven't had an issue with it. It cuts stuff, not really sure why it would be different from a hypertherm.
BD1
north side
MOTHERS DAY PRESENT !!!!!
PROCESSES Plasma
MILD STEEL CUTTING CAPACITY
Rated
5/8 in (15.9 mm) at 13 IPM
1/4 in (6.4 mm) at 64 IPM Maximum Sever cut of 7/8 in. (22.2 mm) cutting at 40 amps (240 V service).
GENERAL SPECIFICATIONS Input Power
120 - 240 Volts, 1-Phase, 50/60 Hz
Rated Output
40 A at 140 VDC, 50% duty cycle
27 A at 91 VDC, 20% duty cycle
Welding Amperage Range
20 - 40 Amps
Net Weight 21 lb (9.5 kg)
Pressure Flow
6 SCFM (170 L/min) at 90 PSI MIN (621 kPa) 120 PSI MAX (828 kPa) :thumbup:
APPLICATIONS Construction
Farm and Ranch
J
Joe69
Muncie, Indiana
The one I've used in the past was a Hypertherm. The selling feature was the auto restart for cutting expanded metal. The torch is made by Hypertherm, or so I was told.
Joe
MarkG
Elgin, IL
PROCESSES Plasma
Rated
Rated Output
20 - 40 Amps
Pressure Flow
Farm and Ranch
LOL!!! But you don't know my Mom! She'd probably like it and not let me use it! :S
