Needs a bigger trunk
@Ratchet
Once I had take these.
View media item 20067
But I change them with these.
View media item 29619
View media item 29620
View media item 29621
The one with the yellow handle is older. It hasn't the black coated and the handles shape is the same with the rahsols.
The other with the blue handle is the most expensive screwdriver of gedore. It's because the shaft is polished?The handle is identical with the new.
View media item 23904
My dealer has a full set of torx screwdriver with the blue handle and some sizes from slotted and philips with blue and yellow handle. If you want some let me know.
not seen the yellow ones before
would be interested in the torx set and others though (although no doubt my other half will question my need of more screwdrivers....)
Oh man, I gotta get some of the blue ones, that handle and finish are awesome! Are they current production? Can any of our European pushers.... err, distributors, get a hold of them?
Nice find on the Steinel.[snip]... Steinel... [snip]
*snip*
The Facom 1/4" ratchet is rather bulky so be aware of this if buying one. *snip*
Monte, What do you think about the wrenches Matador sold in Bauhaus. they are a good quality?
Some of their stuff are obviously good stuff, made in Germany, and the price is very good - according to Monte, the price in Bauhaus is 30% under the list price. And way under the price of Hazet, Stahlwille etc.Hi Bullyboybg,
I´m not Monte, but will try to give an answer anyway...
Matador is "a mess"...Some of their stuff are obviously good stuff, made in Germany, and the price is very good - according to Monte, the price in Bauhaus is 30% under the list price. And way under the price of Hazet, Stahlwille etc.
Two matador "meat-bone" double ring wrenches, one made by Matador, the other made by ??? - still "Germany" though...
The sad side of it, is that they tend to buy more and more stuff from suppliers in Taiwan or India (I´ve found HR wrenches on the Matador stand with Matador labels).
View media item 25813Two Matador sockets, the left one (fruit skin finish) made in Germany, the right one (shiny "USA-type" finish) made in ???
So hurry, and look for the Matador tools with "Germany" forged into them...![]()
I thought these types of companies were more resistant to such quality degradation.@ Alfajuj, the 600N series first appear in the 1994 catalog. Probably all the N-Series started in that year.
Not really in too bad a shape, but one of the bearings (both original) was bad. The zerk fittings both worked ok, but for some reason the grease wasn't getting through the wadding to the bearing so it had run dry for ages presumably. The other bearing was ok, but both are being replaced with new sealed bearings (I need to get those press fit onto the rotor hopefully tomorrow).
Anyhow it came apart, was dipped to remove the paint, and I finally got a bit of a break in the weather to spray some primer:
View media item 29645
It'll look good once finished!
Can I ask what you dipped it in to remove the paint?
FYI, if you do not have a press, motor bearings are generally only a light press fit. So if you can find a length of tubing the same size as the inner race, you should be able to just tap them on with a few firm blows
Looking good so far on the old Wolf.
They both describe them as being for Canon Connectors.
I did try and drift the bearings on using the pipe trick, but no joy -they didn't even go on far enough to get stuck. I had to buy the puller I posted pics of earlier though to get the old ones off as well though, so I wasn't too surprised -they were stubborn coming off.
I would put the rotor in the freezer for one night, if it's possible. And gently heat the bearing, but not to hot or you will ruin the seal. Sometimes that is enough to fit.
Good luck!
Elora 870/1 straight from the german Bundeswehr via ebay.de. I really liked the design and once I put my hand on it I knew that this one I would use. Very nice grip. 3/8" drive and 24 teeth.
It has an oil hole that was filled with gunk and the ratcheting felt as harsh as the gunk suggested. The cover plate was a real tight fit so I didn't open it but sprayed it with Bräkeleen and worked it until all the goo was out and lubed it with oil. Feels good now.
Shown with an F936 for comparison. Anyone have any insight as of when these where produced?
Then I took it all apart and cleaned it and it was okay.
Looks like we bought it for the same reason and had the same hands on experience with it.
A quick search showed repair kits for between €21 and €30. Add the shipping cost...
With regards to the age span of those ratchets I sent an email to Elora and will report back if I hear anything.
Bummer about the lost sockets.
*snip*
I've got the Elora JC set, which includes Whitworth sockets, but I'm missing some. I've been having a terrible time locating them. I ordered some from a company in the UK called Baconsdozen, but they got lost in the mail
He was really good about it and refunded me, but that was the last source I could find for the old 3/8 drive Whitworth Elora sockets. It bugs the hell out of me having those holes in the set!
Granted, I presently don't own any vehicle which actually uses whitworth fasteners, but it's a great weirdness coup to have them! Just in case I buy an old Triumph or Norton or something![]()
I have some DOE in whitworth but want me some sockets as well. Just in case.
Hard to get a feel for the color in the bright sunlight but I think that it will look mighty good on the workbench and being the source of much envy once assembled.The Wolf gets a couple of coats of shiny red paint. It's actually slightly darker red than the photos show, and has turned out really nice. Hopefully in the next couple of days I'll have pics of it mostly back together.
Hard to get a feel for the color in the bright sunlight but I think that it will look mighty good on the workbench and being the source of much envy once assembled.![]()
The HAZET 60's catalogs (61, 62, 65, 67, 69) are online and free to download:
Here http://www.facebook.com/hazetwerk to find in the timeline...
...and also here http://www.hazet.de/unternehmen/historische-dokumente/ .
Canon connectors are the male/female connectors used in audio and video applications. The most common type are XLR audio cable connectors which are 3 pin. Other ones could have 5, 7 or more pins.
Gedore 1993U-10T (1/2"). My favorite when it comes to strength.
