10.5 outlaw
I used 80 grit sanding pad,And i just started grinding randomly Back and forth,Side to side.And yes i did the same thing on the pool table legs.
next will be a trebuchet. although the property owners association might have a problem w it.
What kind or brand of bender are you using?Hello, new guy here. I am big into Sim Racing and needed a cockpit/rig, so instead of spending hundreds even thousands on one pre-built, I worked with my Pops and came up with this.![]()
Great site by the way, haven't posted much but very useful info, thanks!
Was bored,So i threw this together!
HEX bit holder
Gonna do a couple more for the allen sets
Here is one I made, there are many many more.....
I was gonna add a length of tubing between the stands but it turned out not to be necessary. The whole thing is very stable and balanced! Built the contraption in a day and it cost me virtually nothing 'cause I used materials I had on hand. I greased the inside of the engine stand heads and this thing spins super easy and it's very easy to roll around! Simple to put together. If I can do it, anybody can!
I definitely have to make one of these
LS1 Cam Lamp
My winter project:
Tired of shovel/wheelbarrowing, so, "Mini loader" for the tractor!
Mock up:
Now metal:
Not quite "done" yet, but FUNCTIONAL!!!!!
SUCCESS!!!
And finally, after paint, reworking a cylinder bracket, and changing the
cylinders from red to green:
love that cam lamp. I have an old ls1 cam lying around myself, plan on making one similar when I finish building the motor
My winter project:
Tired of shovel/wheelbarrowing, so, "Mini loader" for the tractor!.....
.....And finally, after paint, reworking a cylinder bracket, and changing the cylinders from red to green:
I made a beater from some old pipe.
LS1 Cam Lamp
Valve Spring removal tool
May I ask how you ran the cord for that lamp? I don't see anything, and I highly doubt you drilled through the cam to get it up there...
or it's battery powered.
Nice work though! I'm doing that soon.
I would like to see the video of you manually throwing that through the side of a STEEL 55 gallon drum... You must have Arnold Schwarzenegger armsOne of many, and not real impressive, but most people get a kick out of it as I have it on a nick-nack shelf in the shop. I made this back when I was ~13 and started to get into bladesmithing. Made out of 3/16" spring steel. It was rust blued, but has since worn off from extreme use. It is as sharp as it looks, both wings are sharpened to a shaving edge and all points are pointed. Lets just say I would hate to be on the receiving end of it. At 20ft I can put it through 1/2" plywood or one side of a steel 55 gal drum.
