blindbug
There has been a lot of discussion lately about the apparent push of Sears moving COO of Craftsman RP tools overseas. I was in Sears yesterday and happened to come upon a matching set of 14pc combination wrenches where the COO was China on one and USA on the other. I wanted to do a little investigative work so I took a look at the 2 sets side by side and took the pictures attached.
1. The China set is NOTICEABLY heavier than the US set, so much so that I could have EASILY told you which set was which with my eyes closed, based on weight alone.
2. When I opened the sets to see what may be causing this, I found that nearly every wrench visually had a larger girth and a hand-held sense of more weight to them. Length was nearly identical for all of the wrenches I compared side-by-side.
3. The additional issue I see on the China versions is a lack of COO on the wrenches... which I can only assume is an attempt to hide the fact that these are being made overseas. The only place you will find the COO is on the back of the box/blow molded case, which brings me to:
4. The blow molded cases were almost identical, however the US version has the details molded into the plastic while the China version has a sticker. The sticker is NOT that sticky, and in a few years it will be hard to tell the COO, because it will fall off or scratch off. Which, in my opinion, is another attempt to obfuscate the COO to consumers.
5. The finish on the US versions have a very dimple like pattern, probably from sand molds used in processing. The Chinese version has a texture similar to a chewing gum wrapper, and side by side is much less appealing. (The picture that just says 'Chinese Finish' below is between (2) US made wrenches, you can really tell the difference. It almost looks like my camera is out of focus, but I assure you, it is not.) Also of note is the higher rise on the polished section of the wrench in the Chinese version, again adding to the overall weight and girth of the product.
Once I saw them side by side, I could go down the aisle and easily point out which wrenches on the shelves were US made and which were Chinese without looking at the COO information. I know that a wrench is a wrench and the nuts and bolts don't know the COO, but the quality is noticeably less appealing, and the use of more steel in production and heavier tools makes using the China versions that much more of a pain in the neck (literally). The additional girth also makes it a tough fit in tight clearances when under the hood or whatever.
Personally, I would be looking for old stock if you are going to buy Craftsman RP at this point. I'd love to know what everyone else's (totally mild
) opinions are on the attached pictures and above statements....
(Sorry if I have mis-spellings, I am posting from my phone... coincidentally the pictures are phone pictures too, so sorry if not great at showing what I am seeing)
