IndyGarage
A grinder? No way. A plasma cutter? Maybe but until a few days ago, I didn't have one. And I wouldn't be learning anything new if I just used a grinder or plasma. I don't do this for a living. So the set up and mounting the part to the table is a challenge.
It's not about the time I spend making a part if it's how I expected it to turn out. I wanted it to be a perfect arc because otherwise it would look cheap to me. I don't have a steady hand so I make jigs and fixtures for as much as I can to make things look consistent. I want it to look professionally built.
With that being said, you may not like my next post.
I've acquired an old t slot table. It's about 14" x 14". I found it under a pile of parts in a surplus store by my inlaws. I got it for real cheap. I don't have t slots that small so I drilled and tapped 20 3/8-16 holes to use my clamping set. I may eventually open up the slots if I can get a cutter. It's all two tiered so I can use clamps near the edge too.
Reason I did this is because my welding table isn't flat. It's one of the first things I ever made and I didn't have the tools at the time to get the bow out all the way. And now it annoys me. So I've always wanted something flat that I could clamp to so I don't warp parts and to hold things still. Overkill? Probably. But I like it that way.
So the next several posts will be a little repetitive because I'm just building the other side of the track frame. But starting off, it was a lot easier to weld the motor mount block to the tube.
I wasn't criticizing, I thought it was interesting. You certainly don't mind putting in the time to get it the way you want it.
I've seen people do amazing stuff with hand tools, a file and a grinder.
even a Yanmar would fit. Seriously looking good.
No the quality of the build does not say cheap.
