What a great project!!!
I don't think I'd try screwing around with a rack and pinion... just rebuild the stock box and front suspension. I've driven a '54 Buick and '61 Chevy Suburban daily for years... There is no reason for a rack and pinion. Power steering, yes, but not a rack.
Disc brakes are nice too.
I wonder if that mangled floor is from an exploded clutch. It seems odd that a guy would drop in a plain FE with a 4bbl, and 4-speed, and not use the stock bellhousing. But it WOULD make sense to stick an Ansen in there after having The Thundering Herd come through the floor once.
-Brad
Brad,
Funny you would mention a clutch explosion in this '56, because I was driving a '56 that did explode!!
My buddy Steve Wicks had a cheap style 2 door hardtop (CustomLine?). He worked for a guy running a oval track '56 Crown Vic. They had a 312 stroker engine, about 345 cubes, they retired from service and my buddy got it from them. He puts it in his car with a 3-speed and a floor shifter.
I was known as a pretty good speed shifter and he wanted to wring this Ford out, so he put me behind the wheel. After a few starts and stops to get the feel of things I get ready for a banzai run. Old Atlas Bucrons semi-hooked because he locked up the rear end.
Went for second gear and all HELL broke loose. Several things happened in a blink of an eye: 1) a loud explosion 2) I felt something hot against my thigh 3) the tachometer was swinging under the dash board by its wires 4) We had a flat rear tire as we coasted to a stop 5) We both then almost **** in our pants with that WTF happened look at each other.
Damage assessment: 1) Hole in floorboard next to the gas pedal 2) hot thing against my thigh was a piece of hot cast iron pressure plate grenade fragment 3) Ruined tachometer and his school shop handmade walnut wood under the dash mount, grenade got it 4) bell housing was non-existent, blew apart and we drove over it puncturing a tire 5) part of the engine block left with the bell 6) the only thing holding the engine and ****** together was the tip of the ****** input shaft that was still in the pilot shaft bushing 6) the pressure plate tin cover was still there, but the plate and springs was scattered all over the road
How I missed being fragged I don't know???? But in a couple of days my buddy was back up and running, but with a Schieffer clutch plate outa' the same oval track car. No more speed shifting in that thing.
I felt real bad about what happened, but I didn't do anything wrong, like miss a shift!!!!!
So the moral of the story is, "For the want of a blow-up proof bell, you can damn near total loss your car!!!"
Reminds me of a guy I worked with. He had a Pinto wagon. The water pump shaft broke, fan took out the radiator, stuff on the front of the engine and hood. It totaled the car!!!!!!! Come to think about it, I had a '69 BBC 427 4-speed Corvette. Fan came apart took out the radiator and then a rear tire. Hood was safe. Patched it up and sold that PoS. I've never had another.
Frank
