1/4" drive female to female adapter. Any such thing?
supra90turbo
Central MA
I'm looking for exactly that. 1/4" drive socket that the drive and driven sides are the same.
Anybody ever seen such an animal?
Thanks!
Kurt
metaleltr
Western Ohio
Iv'e seen something similar in 3/8 drive, but that would be a distributor wrench connector. Not sure if any such animal was ever made in 1/4" drive.
supra90turbo
Central MA
That could work, I'm looking for something with a retainer hole for a detent ball though.
I think I've found snap on makes a bit socket with replaceable bits via set screw that may be right.
Thanks for the info so far, guys!
supra90turbo
Central MA
Whoa, you guys are fast! Lol.
I'm not in a bind, but SCScout is right on the money!
Murphy, still a good idea considering I'm somewhat cheap and a decent welder!
supra90turbo
Central MA
Out of curiosity, what is the application of this?
In my glovebox, I keep this little kit I made up.
Sockets and bits fit into the handle of the driver. 8,10,12mm. Flat and Phillips bits.
Not pictured, a ratchet that I also keep in the bag.
I could use the tm4 1/4" piece as an extension if I had an equally opposite female adapter to use on the ratchet.
I know it sounds complicated, but I just wouldn't feel right if it was easy. Lol
Thanks for the interest and suggestions so far, everyone!
#1SomeGuy
Canada
I picked this mastercraft maximum ratchet handle set up a couple years ago, it has one in it, not sure if you'd be able to find something similar.
SCscoutguy
South Carolina
plinker
Northern Wi
Gearwrench has the same piece, I had gotten a couple. The other thing you could use is a plain 1/4 drive extension, it does work.
supra90turbo
Central MA
Thanks, all. I feel this question has been well answered. I will be looking at Fastenal, at a Mastercraft or Gearwrench adapter.
And yes, I have had a need for it. I know I could just put an extension in the "kit" but I like the compact idea of the adapter.
So, thanks to all that helped!
ollie76
Nova Scotia
Old thread resurrection! I'm actually looking for something similar....
Did anyone ever find anything inexpensive that works? I noticed that some of the options posted above are not active anymore (dead links to photos).
1320
Arizona
Not sure about inexpensive, but - Snap-on TQN139. It is a 1/4" F x 1/4" F torque tester adapter. It's likely that Precision Instruments and CDI make one as well and that the Snap-on version is one of those two.
The least expensive option is likely to be a 1/4" drive 8 point 1/4" socket, but it won't have any retention on the 8pt end.
rlitman
Long Island
if I needed one, I would cut off the business ends of 2 sockets and weld the 1/4" square ends together
I'd consider doing that, and then I'd remember the failures I've had welding to sockets in the past and end that thought chain. Sockets are made from a high carbon steel that ends up very brittle after welding if you don't have an oven to heat treat it.
Plus there's the issue with removing the chrome, and the possibility of manganese in the alloy.
You gotta go hang out on the vintage side, where male to male drive plugs used to be common. Links to kctool seem to no longer take you to the product, but to the category, they may no longer be available, can't search on my phone
mikey03
Could you take a 1/4” hex bit socket and slide a matching socket in the other end? If you got a 6 mm hex bit socket 1/4 drive and then put a 6 mm 1/4 drive socket on the end now you got something you can use
I guess you could take two 1/4 impact sockets and weld them together if your going to do this alot and it doesn’t exist
ollie76
Nova Scotia
That could work!
lund
Yea I was thinking the same thing. It wouldn't have the spot for his detent ball though.
Usually for stuff like this it is for a special application and one can jam in tape etc to make things retain well enough for a limited time. Similar can be done with square (female) type sockets. If you had the need now and then and wanted to be a bit more fancy, you could carefully grind some detents with a Dremel type tool.
KnurledNut
n/a
The Gearwrench adaptor works really well because the sleeves work as stabilizers. It's out of stock on Amazon but that's not uncommon since they are inexpensive and move quick. The last one I got was like $3. The sleeves could easily be cut off to suit a need.
ollie76
Nova Scotia
Which adapter is this?
mhejl
DFW Texas
KnurledNut
n/a
I have one of these. The square drive portion is recessed almost 1/2" on each end, presumably to support the extensions. They come with Gearwrench ratcheting screwdriver sets to provide a long drive extension.
You'd need a couple of short extensions; you couldn't connect, say, two ratchets.
Yes, or just cut the sleeves off.
Some early 1/4" drive socket sets contained a 4-point (square) 1/4" socket. Not sure if that's going to suit your purposes.
I do not believe I have one here. I have a 1/4" hex drive 1/4" square socket (that is part of a small kit).
Why won't a 1/4" square drive 1/4" 8-point socket work?
