supra90turbo
I'm looking for exactly that. 1/4" drive socket that the drive and driven sides are the same.
Anybody ever seen such an animal?
Thanks!
Kurt
Thanks!
Kurt
1/4 inch drive 8pt....
Out of curiosity, what is the application of this?
I picked this mastercraft maximum ratchet handle set up a couple years ago, it has one in it, not sure if you'd be able to find something similar.
I'd consider doing that, and then I'd remember the failures I've had welding to sockets in the past and end that thought chain. Sockets are made from a high carbon steel that ends up very brittle after welding if you don't have an oven to heat treat it.if I needed one, I would cut off the business ends of 2 sockets and weld the 1/4" square ends together
Could you take a 1/4” hex bit socket and slide a matching socket in the other end? If you got a 6 mm hex bit socket 1/4 drive and then put a 6 mm 1/4 drive socket on the end now you got something you can use
I guess you could take two 1/4 impact sockets and weld them together if your going to do this alot and it doesn’t exist
How about a refrigeration ratchet? F 1/4" drive, use an extenstion to gain the other 1/4" F.That could work!
Yep, that could work too! Thanks!How about a refrigeration ratchet? F 1/4" drive, use an extenstion to gain the other 1/4" F.
Usually for stuff like this it is for a special application and one can jam in tape etc to make things retain well enough for a limited time. Similar can be done with square (female) type sockets. If you had the need now and then and wanted to be a bit more fancy, you could carefully grind some detents with a Dremel type tool.Yea I was thinking the same thing. It wouldn't have the spot for his detent ball though.
Which adapter is this?The Gearwrench adaptor works really well because the sleeves work as stabilizers. It's out of stock on Amazon but that's not uncommon since they are inexpensive and move quick. The last one I got was like $3. The sleeves could easily be cut off to suit a need.
GearWrench 890007GDWhich adapter is this?
I have one of these. The square drive portion is recessed almost 1/2" on each end, presumably to support the extensions. They come with Gearwrench ratcheting screwdriver sets to provide a long drive extension.
Yes, or just cut the sleeves off.I have one of these. The square drive portion is recessed almost 1/2" on each end, presumably to support the extensions. They come with Gearwrench ratcheting screwdriver sets to provide a long drive extension.
You'd need a couple of short extensions; you couldn't connect, say, two ratchets.
