gahrajmahal
Hi All, I have started to rely on the helpful opinions I have recieved from you, the members of the GJ.
Back in 2005 I paid for somone to remove the original 30+ year old deck and replace it with this slightly updated design I provided. It was build from pressure treated #1 Pine with a permit and inspection., We interviewed 4 builders and went with the one we liked the best. The original builder works with a helper and is still in business today. We did have to argue a bit to get the curved face along with the uneven spacing of the posts and rails. Once he got the job done he loved the design and has it on his website.
I sealed the deck the first year it was up, top and underside, and two more times over the years. I used Baer solid color stain and latex paint on the rails and supports.
This year I was having someone provide me with a quote to pressure wash and seal the deck when he noticed some mildew on a particular spot from the underside. When we went up to the deck and walked around, the boards in that area were soft enough to put your foot through. It was not soft in that area last fall as the table and chairs we have are right over the now rotted area.
Needless to say I am pretty sick over this as I thought this project was complete and only needed periodic maintainance. Due to lack of finances to hire it out again, I will do the work myself, possibly with a little hired help. I called the original builder and asked about the vender where the wood was purchased. I plan to go to the lumber yard and see if I can get the rotted boards replaced under warranty. Most pressure treated boards say lifetime LimitedWarranty. What this means I don't know yet.
I plan to replace all the decking. I will also replace the affected joists. My question to you all is should I upgrade to cedar?
A similar deck I built on the front of the house is a little older. It recieved the same maintainance and is just fine with the exception of some twisting of the boards. When I built mine I used boards from Home Depot, but I stained everything prior to cutting and assembly. I also gapped the boards 1/4" using a paint stick. The builder specifically provided no gap between the boards explaining once the boards dried out and shrank they would have the perfect gap. Well, they never did develop this gap and routinely had leaves and other plant matter jamming up the gaps.
Whats your opinion of the wood failure. Mold, dry rot, poor build practice, lack of maintaince?
Any build or finishing suggestions for the new repair would be greatly appreciated.
