If you don't care about the part numbers on the handle you can do a transplant. I did this with a friend for a ratchet i gave him with a knackered handle:
Is that hard to do? That's a screwdriver handle isn't it?
So how'd you do it? If I were going to approach that I think I would first drill the handle to the right id. Then sandblast the handle of the ratchet. Put plenty of high strength epoxy in the plastic handle, then slip it over the ratchet handle. Wipe off any excess epoxy that oozes out. Am I close?
Nope.
Put a cloth around the shank of the ratchet in a vice, lever off the handle.
The for the screwdriver, find a socket that's end matches the size of the round "cut" around where the shank goes in. (This prevents damage to the handle during removal) then put a cloth around the shank and clamp it in a vice. Use a prybar between the vice jaws an a socket and lever off the handle. (make sure the bolster will pass through the socket).
the ratchet handle part that goes into the hard handle has a step in it. Drill out the new hard handle out to the diameter of the end of the shank for the length of the ratchet handle that goes into the hard handle. Then drill out the wider part.
The ratchet handle has "wings" on it, to stop the hard handle coming loose or spinning. Fold up a cloth and put it on a hard surface, put the ratchet head on it, line up the hard handle and hit it with a soft-faced dead-blow hammer.
Job done.
Just remember one thing, i did it FIRST.![]()
I have changed them to.
Stumbling onto this sight got me to digging around.
Some extras that will need a home one day. The SK are no longer made. All are USA.
(Wanted to test a pic also.)
I'll contribute one. This is a 1933 Snap on F-7.
Here's one I havnt seen yet ( suprisingly)
Its a late 50's early 60's Blackhawk.
3/8"drive, about 7 1/2" long.
Thanks.This Blackhawk is sweet too, Glenn! I've never seen one of these either...
And you think it's from just after New Britain acquired Blackhawk? What makes you think so?
the handle certainly looks like new brittans!
Just the patent number on it (which I should have posted).
'Pat. no. 2554990& pat. pending.'
I think the 'pending' could be this.
http://www.google.com/patents?id=kjlrAAAAEBAJ&dq=2981389
This is kind of a cool Challenger set that I found at a hawk shop for $4, as far as I can tell everything is exactly the same as the Proto stuff other than the name.
) .Personal preference/application, I find S-K suits my wants/needs well (helps to have relatives at the plant, those stories for another thread one day).
Alright, now for the extra long handled 1/2" drive ratchets from the big drawer, all Made in U.S.A. ..........
wrenchr, you have really nice collection; looks like mostly primo Snapon stuff!!!!Did you buy most of it used or new off the truck?
I have a very similar Fleet 1261 ratchet from perhaps a few years after yours and I've noticed the Challenger & Fleet (& likely Vlchek) tools from that era (at least) share model numbers. I don't suppose that Challenger is a model 1261, is it?
