I need to loosen a pipe plug that has a male square head that is about .440" from flat to flat (more or less 7/16" or 11 mm square).
I have found some sockets that have a square male business ends designed to fit INSIDE pipe plugs whose driven square ends are concavely interior within the plug, like a set screw.
But I'm having trouble finding sockets that have a square female business end designed to fit OVER pipe plugs whose driven ends are convexly exterior to the plug... a square jutting outward, like a plumbing pipe plug.
The ideal socket would have a 1/2" square drive female hole on one side of it, and a 7/16" square drive female hole on the other side of it. I have never personally seen such a socket.
On Edit: But I've seen pictures of them now on eBay! However, I'd rather not wait for shipping etc. Is there a local bricks and mortar store that has them? Like Sears, HD, Lowe's, or any auto store? I've checked HF website, but maybe I'm not using the right terms?
I have three 8 point sockets that will fit over square pegs, but these sockets are quite small, and only 1/4" drive, and are too small in both size and torque capacity to loosen a rusted and locktited square pipe plug.
Access is very limited, hence an open ended wrench will not do the job. I will need to put this dream socket I'm seeking on a 6" extender to clear obstructions, and then attach the extension to a swivel headed 24" breaker bar to loosen. Or an impact gun. Not sure which. I need the right socket first though.
I'd appreciate some pointers... or better yet, some tool names, stores, and/or part numbers!
