snap on vs fertilizer?
Andersonfarms
NoDak
Hey guys I was putting a packing wheel on our planted tonight and I brought out the good old fn100... as it was sitting on a row unit I accidently bumped it (go figure) and dropped into some 10-34-00. How well do you think it will hold up??
A
Andersonfarms
NoDak
Ya I took if out after like 5 seconds it was dark so i didn't notice it landed in fertilizer right away. I wiped it down as good as I could but I don't know how well that will work
deter
Indiana
did you oil it up really well afterward? maybe drop it in a bucket of oil for awhile
ken w.
Western New York
I lost a wrench last summer. I finally found it . It fell into a open bag of 10-20-20. It was so corroded I wasn't sure what it was at first.That's some nasty stuff.
CWP1616L
USA
I'd recommend that you completely disassemble the ratchet and wash it out with soap and water. Then dry it thoroughly and re-oil it.
G_P
Central CT
Yeah take it apart. Liquid has more than likely gotten inside and will start rusting the guts out of that ratchet.
Disassemble, clean, and relube.
woody 73
The Great State Up North
Fertilizer will win every time nasty stuff, had a roommate tell me that years ago he was standing next to his tractor and their was a pin hole leak of AH (Anhydrous Ammonia); short story he almost lost his leg spent some time in the ER, you don't ever want to see that guys leg scars.:eek:
McFarmer
I have planted several wrenches over the years, never had any grow. Maybe the fertilizer would have helped.
Of course, I've always used cheaper "seed" .
sk farmer
nd
i was working on my planter this spring and it didn't hurt my sk ratchet. that liquid fertilizer sticks everything together. even after wiping things down with a wet rag the residue still shows up. if it was just on the outside i would keep it well lubed with some sort of solvent that stays on and does noet evaporate. if it got inside i would completely tear it down, soak the parts in water to dilute the fert., spray the parts down in brake cleaner or carb cleaner. then reassamble with plenty of your lube of choice.
Spudland_Dave
Maine
+1
Completely dis-assemble. Dont take a chance.
I'd wash it out with simple green & water...then soak it overnight in diesel or something. Then re-assemble.
A
Andersonfarms
NoDak
16-30 john Deere 7200 with dry and liquid. Ratchet looks okay so far but there is some residue so maybe I'll try to clean it some more
RedFordTruck
I have a masterlock that fell victim to a similar scenario... It worked for a while but is now permanently locked onto a chain. Internal components completely seized and corroded together. Key wont even go into it. I figure I'll eventually cut it off when I see the need.
CWP1616L
USA
You're gonna have a very expensive heavily corroded ratchet if you don't take it apart and clean it out.
