nonhog
Building an exhaust system for my wifes V8 Volvo project.
Its a 5.0 Ford Explorer (stock) I added block hugger headers after messing with the Mustang shorties. (ruined the shorties
So it'll be a 2 into one. system. 2.25 into 3" then down to 2.5
So far I've done well (being my first real system)
I am doing this while the car is on jack stands. So its a lot of up/down
measure/cut/weld over and over. It is what it is.
I'm just tacking it in place (MIG) I'll have an exhaust guy who owes me
finish the welding
Time for my questions:
1) I am thinking I should line up both sides of the head pipes then
tack a couple bars across them to keep them "in place" then pull it down as
a unit to add the 'Y'. Does that sound right. I'm trying to weld as little as possible under the car.
2 I am thinking about making my own 'Y' pipe. (2) 2.25 into 3.
I had a real ugly merge. Cut it off already.
A co-worker who use to work at an exhaust shop told me to be careful with the 'Y' because if its not smooth it could cause a Pffft (tick?) noise. The only noise I want from this system is from the tailpipe.
3 How crucial is the placement of the ball flange? I will make every effort to be sure the flange is square on the 'ball'
Just curious there, not a problem at this point.
Thoughts/wisdom welcome!
finish the welding
