The Harbor Freight PASS/FAIL Thread...
Shadowdog500
Down the shore
central Pnumatic 3' by 3/8" air hose lead, Item 91294
FAIL!!!
Hose rotted out after 3 years. I have quality hoses with several decades of use and this hose can't last 3 years?
aznxstazy
FAIL!!!
I have the red 1/2 hose and I used it maybe a for a few hours and it started cracking....
but that one is also a fail.
IONH
Central Massachusetts
FAIL!!!
I have 2 of the black 3' hoses which have been in use for 4 or 5 years, no issues. They are in a fixed location though and never touched or moved.
danfromsyr
Cicero, NY
X2 agree, I've been using a set for ~6months and aside from a little issue with the release (there's a nub it's supposed to glide over, but binds on, a slight tweak and all is well) they're quite handy for the bumper hitch carrier w/o the pigtails.
I'm thinking I'll get a set of the bigger retractables that Tractor Supply has to compliment them.
it's real nice when you hook the loose end hook and the retracting tension keeps the hook from falling loose off the rings..
2 Piece 6 Ft. L X 1 In. W Retractable Ratcheting Tie Down - Pass
Used these to strap my bike down while taking the Ferry from Milwaukee to Muskegon. Worked great and were very easy to store on the bike. I regret not buying two sets right away.
Shadowdog500
Down the shore
My hose never moved either. It is the black hose between the filter and the reel. It rotted out just sitting there.
Chris
Aeroman
What filter are you using, the short blue one? I got the desiccant (yellow) you recommended, thanks!!!
SCscoutguy
South Carolina
My dad picked up the HF 1.5 HP Electric Pole Saw for $55 with a 25% off coupon a few weeks ago. Well I got around to borrowing it and using it today and I have to say this little saw is pretty awesome. It made short work of limbing out my dogwood tree and cut through some pretty thick limbs with ease. I would have no problem buying it for the $79.99 it is priced at right now.
http://www.harborfreight.com/15-hp-electric-pole-saw-68862.html
Sea_Chicken1
Oak Harbor WA
The Central machine drill press is garbage. The pulleys are loose and the chuck is sloppy, not to mention it is gutless for 3/4 hp. The Pittsburgh ratchet and sockets work well for what I paid and the 10 to 150 lb torque wrench is nuts on. The Chicago brand drill that i had caught on fire in my hand the second time that is was used.
So far if i have to use HF hand tools in a pinch I will, but their power tools ****. You get what you pay for and HF is good to get tools to start with and upgrade as you move on.
Shadowdog500
Down the shore
The blue one is from HF as well. It is just a filter and regulator. I owned it allready so I just put it in line to catch any dessicant that made it into the line. If I didn't already own it I don't know if I would have used one.
The dessicant line dryer is a major pass. I ran my Pnumatic vacuum to pull down my AC in my jeep for over an hour and I couldn't believe how much water came out of the dryer wen I was done. In addition my bead blast cabinet stopped clumping when I got it.
Chris
Recoil Rob
NY
Any reports on the 69039 Portable garage on sale for 189.99? will it last a year or two?
jakemac
New England
I've had mine up for almost 3yrs. I use it to store a trailer and my canoes/kayaks. It's both pass/fail, depending on how much extra work you want to put into it to set it up to last.
I posted a review on their site at the time. When I first bought it, the pipe channels in the end tarps were too small and I couldn't get them to fit. A short set up time ended up taking 3 days. I didn't want to pack it up and take a chance on getting another one that didn't fit the pipes (or worse), so I put a bunch of grommets in the end panels and made up a bunch of bungees to secure them to the frame. The frame is descent, but only has 4 legs, I would have preferred more, but it is holding up (read more at the end).
The cover tarp is a bit thin, but has held up surprisingly well in heavy snow and high wind (the location is somewhat sheltered by trees). I put a silver HF tarp over it to help secure the load, and to use as a disposable to prevent UV breakdown and save the original cover. Rather than securing the tent to the ground (and to prevent rust/rot of the frame) I bolted the legs to a couple of used composite decking boards that I had laying around. I then spiked the boards to the ground to keep it from moving. I inserted pipes into the bottom pockets of the end panels to keep them down, this also helps to roll up the door.
You should be aware that the tent doesn't vent well, so if you have it on bare ground the humidity will build up and drip from the ceiling. In winter you will need to clear heavy snow off the top so it doesn't pool up and create a leak, or rip the cover. A system that I use on a different tent that I have in northern Maine, is when a cover tarp wears out due to UV rot, I just turn it sideways on the tent then cover over with a new one. There must be 10 layers by now. Over time this saves on the cost of buying expensive covers from the manufacturer, and adds strength to the top to resist snow buildup. I've never had a blowout on that one and it's seen -40deg temps.
Last winter I had a 20" pine tree come down next to the HF tent, It scraped the front top corner and bent one of the pipes and the foot. The tent held up and didn't leak. I haven't had a chance to fix it yet and don't know where to get parts, maybe CL will have one that someone is getting rid of to use as parts.
Over-all, as a CHEAP storage tent, it was worth the money. Just be aware that you may have to do some work to get it up and going.
celticbhoy
Alright. So I went to the states today and HF and picked up the 1/2 torque wrench. I didn't just grab the first one off of the shelf, I opened a few and turned the handle all the way up and all the way down until I found one that moved semi-smoothly. You had to really put some muscle into it to turn the handle on some as they usually got stuck around 50 ft-lbs. I torqued the wheels on a few cars today and the wrench is DEAD ON! It gives a nice loud click and a good jolt for feel. We'll see how long it lasts but as of now i'm very impressed. I'm going to see how well it works in the shop this week so i'll report back. PASS as of now.
Along with the TR, I bought a angle die grinder, die grinder accessory kit, 1/4" roto head ratchet (Jet tools makes the same one for 10 times the price, and if I knew about this I wouldn't have paid $50 for the 3/8 rotohead a couple of weeks ago.), Oxygen sensor socket, impact extension set... all of these tools are made in Taiwan so we'll see how they make out.
Revere Cycles
Rochester, NY
2.5 Ton Heavy Duty Steel Floor Jack and 3 Ton Heavy Duty Jack Stands work well together. My wife loves me so much, that she breaks down the family mini van just so I can buy tools to fix it.;):lol::lol_hitti
Not quite done yet, but very impressed with what I have seen.
Pass
2.5 Ton Heavy Duty Steel Floor Jack and 3 Ton Heavy Duty Jack Stands 01
PASS!
I bought the same combo this weekend for some exhaust work I was doing at home. I only do work on my car once every 3-4 months, and even then, I'm not under it more than once or twice a year.
I shopped around quite a bit before landing on these items from Harbor Freight; I must say, I am impressed with what I got for my money. I inspected everything thoroughly for workmanship and play, everything looked as good or better than what I saw at other big box stores. The funny thing about the floor jack was that when I went to pull it out of the box, both Pittsburgh stickers were bunched up and peeling off. That was easy...
TheMadMechanic
California
I'll add a p/n later when I look but I bought the gray blown case ratchet/socket set from HF and I've been using it for 5 years as an industrial mechanic and 4 years at home. I've used the sockets and extensions on impact guns and everything Major Pass. Best sockets and good ratchets. Ratchets even have a knurled portion on the head to use it as a thumb ratchet built right in. Awesome.
IONH
I picked up a 2.5 Horsepower 10" Industrial Tile/Brick Saw today...Got it for $199 with a coupon...Seems like a decent tool...(I had to buy the 10" blade seperately, for $29.)
I'm in the middle of a large tile/brick/paver project and my small 7" cheapo wet saw will not do the job...
http://www.harborfreight.com/25-horsepower-10-industrial-tilebrick-saw-69275.html
I believe I bought the same one, though an older version as it was orange. I did a 110 linear foot paver stone walkway with a herring bone pattern, so cuts on both sides. Was a definite pass for that use. Haven't turned it on since but worth the investment even though the blade, sold separatley, was another $70 or so.
antinym
Any feedback on the 1/2" drive impact sockets?
I have 'em.. no problems. I have the old ones in SAE. The coating was coming off immediately, I put them in a drill and sanded all the coatings off. The sizes are stamped in. So they're hard to read.
I have the newer ones in metric, sizes are printed on the socket, but only on one side. No issues, but i'm a light duty shop.
TAMPAGT07
Palm Harbor, Fl
It looks like it got pretty good reviews.......I hope I don't regret buying the HF blade ($29)...Most of the reviewers suggested a good quality blade, instead of the HF one.....I guess time will tell...:beer:
IONH
HF didn't sell them (or at least mine didn't) back when I bought my saw or I'd have done the same. I was stuck on a Saturday going to Home Depot for one.
Keep it wet and let the saw do the work, you'll probably be okay.
Of course, my vertical/horizontal band saw is still on its supplied blade and I've cut quite a bit without issue while others can't go through their first piece of steel with it. :dunno:
Fishy66
Bonita, CA
HF Leakdown Tester - Fail
item# 94190
The unit works only at low PSI and instead of being another PSI gauge it is merely a "Low, Medium, High" type. For $15 more you can get an OTC that has dual matching PSI gauges so you can use higher PSI and read the difference between the two for accurate leakdown.
IONH
HF Leakdown Tester-Fail
Since you're new, I'll help you understand the goal of this thread.
  1. Include HF part number if at all possible. As the thread is very large, this allows for people to search for that part number without reading through every page.
  2. Describe the reason for a FAIL. A generic FAIL doesn't help us determine if it is a problem we could live with.
Wallyman
West Michigan
Same experience, mine are maybe 3 years old with stamped sizes. SAE and Metric - both PASS (except for the missing 15 and 18mm, just dumb).
Regarding hard to read stampings, fill it with a paint marker (hobby/craft store) and wipe off excess. I used yellow and they show up nicely for a while... cheap and easy.
IONH
Anyone have any luck with the LCD Automotive Multimeter with Tachometer Kit?
Cen-Tech - item#95670
http://www.harborfreight.com/lcd-automotive-multimeter-with-tachometer-kit-95670.html
Pass or Fail?
I have one and used it a few times. I mainly bought it for the inductive pickup to diagnose an ignition issue. It worked fine for that.
As others will say, "it ain't no Fluke" or whatever, but at that price you can't lose if you will ever use the inductive pickup.
genevabuck
fourtythree
WV
http://www.harborfreight.com/6-variable-speed-dual-action-polisher-69924.html
Dual action polisher #69924: Pass
Picked this up to replace a PC that I misplaced years ago. Using the 25% off coupon, it came to $48. Before using it, I broke it open, cleaned out the existing grease and packed it with high temp bearing grease. That was probably unnecessary, but I figured it was good preventative maintenance given HFs track record with power tools. The fit/finish is ok. Nothing special, but seems solid. The velcro backing plate that comes with it *****. Its too big for 6" pads and it wobbles like crazy. As far as using it, its about on par with the Porter Cable DA. The HF might even have a little more power. The car turned out great. Using 6" waffle pads on a 5“ backing plate, the polisher did a good job of correcting swirls and light wet sanding marks on a friends car, followed by a full polish on the entire car. Overall, I'm very pleased. If it holds up for the long run, this is about the best deal going for a DA polisher.
rlitman
Long Island
item# 94190
I had tried this same tester. Also a Fail.
The pressure regulator output was very unstable, so the needle was always moving. I picked up a Matco version of these, and it is so much better.
Danglerb
SoCal
va aviator
My "office" is a company truck, so I need an inverter to run my laptop. When I started I bought a black and decker inverter that has always been a finicky POS. It finally crapped out on me, and I purchased the 400 watt inverter. http://www.harborfreight.com/400-watt-continuous-800-watt-peak-power-inverter-66814.html
The first thing I did was check it out with my multimeter. 111 volts, with a frequency of 60hz. I don't have an oscilloscope so I can't check the waveform, but between my multimeter checks and real world experience, it is 100% PASS.
I will note, the supplied leads with alligator clips are about 2 feet long, so unless you plan on using the thing under the hood you will need to make your own cables. It should also be noted that the capacity of the inverter is greater than that of most power outlets (most are limited to 15 amps... this means that more than about 175 watts will blow a fuse or worse) but for running low current devices like computers you should be fine rigging up a cigarette lighter adapter.
