Between 265 & 485 SQ/FT The 12-Gauge Garage
J
Jack Olsen
Los Angeles
Thanks, guys.
mjbach, the house is pretty standard-issue. I didn't do any design or other kinds of work on it at all. It's my wife's domain, pretty much.
I finally put up the candle-holder thing on the big wall. It has 28 real candles on it that I've hollowed out to accommodate flickering LED lights. It's pretty convincing. When I walked out there the first time, it seemed like somebody ought to be giving me a back massage or absolution for my sins. It's both spa-like and church-like.
Here's night and day:
santagary
Pagosa Springs, Colorado
Hay glad I'm not alone to do that. LOL
I use one of those Ridgid shopvac that has a leaf blower attached to it
I use a black and decker battery operated blower for the garage and barn to blow the hay out rather than sweeping...I make sure though in the barn that with both doors open (north and south) that I'm blowing with the wind.
J
Jack Olsen
Los Angeles
Thanks.
Matthewjb, there is some of the Gothic arch in the candle thing at the top, where the two roof-shaped pieces are curved -- although it looks in the pictures like it's just two straight lines. I don't remember if I thought about doing the lateral pieces in the same Gothic arch shape -- although I know I already kind of thought I'd repeated it enough in the gate. I'm not sure if it's good design or not, but it was easier to simply do the continuous arch on those pieces.
Matthewjb
Yorkshire
It was the top bit that looked straight to me. I guess it's the camera angle.
The continuous curves of the candle holders looks good and you get a lot of light in the area.
Googling 'Gothic candle' bought up this design in case you're bored and want to make something for the other wall :)
aggierailroad
Houston, TX
Jack, I'm curious as to how you ran power to the "candelabra?" I saw your wiring thread on welding web - but am referring to power from the outlet.
J
Jack Olsen
Los Angeles
aggierailroad, I have a pair of 3v power supplies -- each feeds half the light set. They're plugged into a switched outlet with wire running down along the edge/underside of the deck and up through one of the pillars, then sneaking around the back of the wooden frieze thing and into holes drilled in the backside of the frame.
Matthewjb, I agree that they look straight. It's odd, since they're made from the piece of steel on the left in this image.
My memory was that it's actually a tighter curve than the pergola's main arch pieces -- but I think I must be wrong about that.
Conor
Jack, the deck came out fantastic! Looks really great. Makes me want to create some kind of shade for ours. Granted it will never be as nice as yours lol.
Also I just ordered a Cameo the other night finally. I cant wait to start cutting my own stickers.
How does the heat transfer hold up to washing? I could see making some shirts with the kids being fun.
J
Jack Olsen
Los Angeles
Thanks!
Conor, I've done a few shirts and have had mixed success. Granted, I've been using already-used shirts, but I think the issue I've had (smaller pieces coming off in the wash) has also had to do with not getting consistent heat across the surface of the decal. I think it's probably possible to have too much, as well as too little, heat. There are commercial heating press things available for lots of money. My thinking has been to maybe try out a $20 electric griddle for the job. But I haven't tried that yet.
I've been trying to avoid doing all the web-page-building to have the pictures of the deck build available for sending to family members and such. So last night, I added the pictures to a Home & Garden 'rate my space' page. I wonder if someone could click on this link and tell me if the the pictures are showing up.
Home & Garden Link
I keep getting a message that the uploads need administrative approval, but it also looks like it's up and available. Could someone just click and confirm? (I don't think it needs any registration or anything.)
Conor
Thanks!
That was kind of my worry. I'm going to try and cut some vinyl stickers and apply them to the back of a silkscreen and try that out. I found a kit on amazon that includes the 12" screen, squeegee and paint for just under $40.00. If it works it should be perfect (and cheap) for creating professional looking and lasting shirts pretty easily.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Thanks!
Home & Garden Link
Everything worked fine for me.
Jack......if you would, could you go outside of your property at night, after dark, and snap a pic of what the shadecloth looks like lit up? I'm just curious.
classicharleyj
Jack...
I've shared your garage link with a lot of my friends.. and... I'm always blown away by your ingenuity. Great job as usual.
Jim
Dan in Pasadena
Pasadena, CA
Looks great Jack.
I suppose putting a giant flat screen tv out there would disturb the "Wa" in it's cathedral-like atmosphere, but I'd have to do that to enjoy watching Dodgers game out there.
J
Jack Olsen
Los Angeles
Thanks.
Well, the really crazy view of the place would be from the neighbors directly behind out back yard. I don't know them, though -- so while I've left a couple of notes for them making sure the noise from building wasn't too loud, I can't walk over and snap a picture from their side.
But here's what the thing looks like from my next door neighbor's driveway. He's the owner of the garage that is right behind the wall candelabra thing.
Here's day and night:
In real life it doesn't look as bright as it does in that picture. But it's definitely visible when the lights are on.
Looks great Jack.
We plan on getting a video projector and a screen that can lower down in front of the wall with the window and the AC unit. When that's going to happen is anyone's guess. But it would be nice to be able to show the kids movies out there on summer nights.
-Brent-
Utah
Jack, nicely done. You're lucky to have a cool neighbor.
Have you had any weather to deal with yet?
Dan in Pasadena
Pasadena, CA
Oh, another great dad idea.
I do the same while camping using a laptop and project on a white panel on the side of my camper. It usually draws other campers asking if they can bring a folding chair? Gets to be a small crowd & quite the ice breaker.
slik560
Kansas, USA
I see a new version of "This Old House / Garage / Porsche" with Jack Olsen hosting. ;) I'll have my people call your people. :)
J
Jack Olsen
Los Angeles
We had the first 'movie night' on the deck. The kids hadn't seen Toy Story yet. They got their sleeping bags out and had a great time. These video projector things are surprisingly good.
But what about the garage?
I cleaned up today, and the camera was sitting there on the tripod from when I took the last pictures of the deck. So I snapped a pair of pictures to show how the place can go from messy to clean fairly quickly.
Here's a 15-second video that shows the before and after -- with 28 minutes passing in between, I would have swept up that last pile of dust, but I had to go to be at a Father's Day thing with my son at 2:00.
J
Jack Olsen
Los Angeles
Thanks. It got messy again today, since I have a track day next week and I had to throw together a replacement wing for the car on short notice.
Here's the old one, in use:
Why? Well, the thing melted. It was made of Spyderfoam, which is a fairly rigid foam that's used for making surfboards. I didn't imagine that a surfboard material would have a low melting point, but while I was working on the deck I left the car outside on a hot day and didn't roll a window down. The wing was still inside, since I'd packed it there for the drive home from the track. It must have gotten above 150° in the car? I don't know for sure, but the wing's heat-shrink coating bubbled off and the foam itself melted.
The carnage:
So, I'm back in the wing building game. :) The goal for this one was to have it cost no money at all -- which was possible, since I already had a lighter-weight foam core that I planned on eventually vacuum bagging with carbon fiber or fiberglass. But there was no time to teach myself that today.
So the first step was to get the old hardware off (and out) of the damaged wing. The brackets, end caps, Gurney flap and inner spar tube were all still useable. I just had to go at them with a wire wheel to get rid of the old adhesive. I had a half a tube of the structural adhesive left over, which I hoped would just be enough to adhere the stuff to the new EPS core. Here it is setting for an hour, which is all I needed with the 3M DP110 adhesive.
EPS is the stuff Styrofoam beer coolers are made out of.
To cover it, some RC guys use heat-shrink coatings or packaging tape when budget is an issue. I had some leftover adhesive and also some vinyl tape that I'd used to cover the padding on my roll bars. I figure if it sticks to the EPS, then it ought to stay put in the heat, since it was on the roll bar in the hot car and didn't come loose.
Here's the first piece of tape put in place. It seemed to make sense to do it perpendicular to the direction of the wing's travel, but it was more straightforward to do it parallel, like this. Much easier to get around the brackets for the uprights, for example. And if it does come loose, wind won't pocket in the same way as it would with a perpendicular edge.
More tape:
And done. Quick and cheap. The longest part of the project (aside from letting the adhesive set) was putting on the tape, which took about half an hour.
It's not going to win any beauty contests, but it ought to give me the downforce I need when I go out next Wednesday.
WhiteTrash
Jack,
It had been a year or so since I was last on GJ, and I had followed your thread up until then. Now I have caught up on the last 30+ pages since my lapse. You still amaze me.
I really like the deck. And the gate. Did you ever get the candle in the gate wired? If not, I was thinking of an option I used when I did half doors on my K5 Blazer. There is a product called Jamb Tac that is basically two contact points that touch when the gate is closed. Granted, you would lose the light with the gate open, but you wouldn't have any wires running through a hinge.
J
Jack Olsen
Los Angeles
Thanks very much, Whitetrash.
I did get all the candles wired, finally. The big candelabra thing was a pain in the neck, since welding the sections with the wires inside the tubing melted some insulation and made some surgery necessary. But it all worked out. The hinge junction for the gate wire has worked fine -- I wouldn't like the idea at all if it was 120v. But it's a 3V line, so the risks are minimal. You can see the candle working in this Friday-night-movie picture.
And the wall candle thing is going at full strength in this evening picture:
The deck has surprised me in how essential it's become to our daily routine. It might be because every night I try to get all the toys and art supplies and other stuff left by the toddlers put away again. But it's now where we eat dinner almost every night and where the kids can play with minimal supervision while we get ready for work in the mornings.
It was a lot of work, but I'm glad I finally did it. I just did a quick search and my first mention on this thread of the back yard project was three full years ago. And that was not the first time I told my wife what I wanted to do. She was extremely patient. But it all came to a good end.
J
Jack Olsen
Los Angeles
Jack: What's the material stretched over the overhead canopy?
It's Coolaroo Shade Fabric. It's made out of Polyethylene. I cut this piece in two and sewed the sections together to make a square.
How does your canopy hold up during strong winds?
We'll see. The piece I used over my front patio has been up for three years and has seen 75 mph gusts without any issue. But I think that piece has some odd aerodynamic protection from the adjoining roofs. It never even ripples in the wind.
The strongest winds this new piece has seen have been about 35 mph. It was fine with that. But the next time we get a big storm, I'll be out back watching to see how it does.
Kinyocase
Missoula, MT
I've perused through about 45% of this thread, and I must say...Absolutely Astonishing. Starting from the original shop pictures through all the changes in there to the magazine stuff, straight into the deck and pergola! This is one of the most inspiring threads I've seen during my short visit to these forums. What you have done is a work of art around your place and the Friday night projection location is one of the coolest sights in my opinion for the kiddos. Kudos on a well done place to play and work!
J
Jack Olsen
Los Angeles
For my own personal preferences, I'd like to bother the neighbors with the sound of the Porsche 917s in Le Mans.
But it's the toddlers who decide, and the closest I've gotten so far is the 1969 version of Herbie the Love Bug. :)
