Unusual Compressor
Zrexxer
Pflugerville, TX
I've owned a lot of compressors and used a lot of different kinds of compressors, but I've never seen one like this before today. Pictures are from a CL ad. Anyone else ever run into a direct-drive V-twin like this Atlas Copco? I'm wondering if it was purpose-built for some specific application.
91bronc300
It's hard to tell from the picture but it looks like the motor shaft might not be directly inline with the crank centerline, it looks a little dropped, or maybe my eyes are wrong. What about a planetary transmission, could there be one in that coupler? So that's a 1725rpm motor?
Looks neat anyway.
Craptain
Tampa Bay FL
Don't believe it was anything special, except for the quality. Atlas Copco are not as big here as in Europe. But that direct drive style has been around for a while with them. It is a very high quality machine and the price reflects it. You will typically find they run 2 to 3 times more than any other similar sized compressor. BTW what was the asking price?
Rico.
England
My compressor is a direct drive V-twin 3hp, with a horizontal 50 Litre tank.
It uses oil and is quiet enough, or maybe not too loud is a better phrase.
It sits happily under one of my workbenches, is quite compact and works
perfectly for my DIY uses, and has done for a few years now. I can definitely
recommend the setup.
Z
Zrexxer
Pflugerville, TX
I've seen lots of direct drives before, but always on lower end stuff like Sears compressors... haven't seen one on an industrial machine like this. They've got this one listed a s 2-stage, but I don't believe it is, just a two-cylinder single stage.
And yeah, it's one of dougdeals' listings. And yes it's 3-phase. They want $824 (+tax) for it. I'm not in the market, just intrigued.
930dreamer
Amarillo,TX and Stinnett,TX
Or best offer.:evil:
Grounded Ken
Greer, SC
Atlas Copco
LE Single stage oil lubricated max. pressure 145 psi
LT Two stage oil lubricated max. pressure 218, 290, or 435 psi
LF Single stage Non-Lubricated max. pressure 145 psi
Available from 2 hp to 20 hp
Pricing starts at $2741 for a 2 Hp, $11,639 on a lubricated 20 HP, and $14,104 for a 10 Non-lub. Not the kind of stuff for your normal garage. Just imagine what parts pricing is going to be like!
This machine has been around quite a while. Very reliable, very expensive to buy and parts are even higher.
Z
Zrexxer
Pflugerville, TX
Atlas Copco
This one is 125 psi max, it was on a label in another picture I didn't post.
TwoInch
NW INDIANA
It's hard to tell from the picture but it looks like the motor shaft might not be directly inline with the crank centerline, it looks a little dropped, or maybe my eyes are wrong. What about a planetary transmission, could there be one in that coupler? .
thats a lot of diagnosis from a simple picture.... i dont see how you could even attempt to see that with those pictures.
