theamcaddict
I have been finding myself doing more on car pressing and pulling lately. What is everyone using and also repurposing?
Exhaust tubing separator I got from the Eastwood Company. I got this specialized tool because I was restoring the vehicle and I wanted to re-use the parts.
Are you talking about pulling bearings, steering wheels and such?
big *** impact wrench? 3/4" or 1" drive lol some penetrating fluid and blue wrench.Off topic I know, but I have a question regarding pullers. I have a 17 ton fixed plate puller. The screw is seized in the plate. The screw is about 1 1/8" in diameter. I'm guessing it's cross threaded? Anyone ever had a problem like this? Got any suggestions? I have pulled and pulled and pulled, even added cheaters and I can't free it.
I recently picked up a K tool USA 70323 to pull the harmonic balancer from a 2.0 plymouth breeze I was working on. It was not intended for that application but it worked very well. I am going to try it on a u joint next.
I have this set from KD Tools. I used the ball joint separator a few weeks ago and ended up bending the stud, but it separated the ball joint ... and with a loud pop.
Yup ... tried just the hammer on the other one and didn't work; had to resort to a pickle fork, which did work. Ended up replacing both lower control arms since the compliance bushing was shot.I assume you know to apply lots of pressure and then hit the side of the spindle with a steel hammer. The shock causes the tapered hole to actually change shape slightly/temporarily and the taper falls out. I rarely even need to do anything other than hit the side of the spindle two or three times and the whole thing falls apart without any other help.
Charles
I owned a 2.0L Breeze, did the timing belt twice. The FACTORY manual simply tells you to use a three jaw puller, so yes, that is an intended application for it. To reinstall the "balancer" (its not, as its perfectly balanced and not keyed to the crank, its merely a pulley) You use a piece of threaded rod *I think* 12.5mm x 1.5 , screw it in where the bolt goes, slide the pulley over it, and install a couple of greased washers and a nut and carefully drive it on. Got the metric threaded rod at Fastenal.
Charles
You'll be lucky to save any of it if the threads are destroyed.
These are a must in you work on engines, p/s pulley pullers & installer. these are snap on. Once in a while I'll run in to a pulley that's too big for the small one & too small for the big one, is there a middle sized puller?
The second is my big SO kit, very spendy, but very handy.
I'd love to buy that whole settup with the board and all - my first lead mechanic (sort of my mentor) had the full cabinet with everything they offered back the early 90's, but I still have not brought myself to spend that much.
I've pieced together what I really need for my work along with taking care of the personal projects:
What is the red one?
