thebeekeeper1
I got stupid--and lucky--last Sunday and may have bent the spindle on my drill press. It is a 1960s Delta, was in excellent condition, and now has significant wobble in the chuck. The tapered portion of the spindle is not visible enough (only about 1/8") to tell if that's where it's bent or not.
My question is, can the chuck be canted on the taper, as in is the taper steeper than the inside of the chuck so it only rides on the topmost portion and could be knocked off, inducing a wobble?
I'm very lucky to not have been injured or inflicting damage to other stuff. If anyone cares, I was drilling out two broken lug bolts from a tractor hub. The hub is tall and round, so I couldn't figure out a way to clamp it in place, so I figured it was heavy enough (probably 15#) to not be grabbed and spun by the bit. I figured wrong.
The first one went smoothly, and the second one did, until the last little bit of the largest bit. It spun at 550 RPM for a number of revolutions, then flew off and bounced around on the concrete floor. In front was . . . me, and to the immediate left was an Anderson sliding patio door. Elsewhere was a radial arm saw and other stuff. It managed to miss everything, and not even break when it landed on the concrete floor.
I wasn't so lucky with the DP chuck, however.
I tried to remove the chuck but knew better than to pound on it. A wedge wouldn't budge it, so I'm hoping someone can give me advice. Thanks!
