MScott
I have tried to change my avatar to a gif file but it shows up as a non moving picture. Is there a trick?
Interesting. 80 visites and not one suggestion. Perhaps I should PM someone who is already using a gif for an avatar to see if they did anything special. I just don't know if it is a problem with my system or with the gif file itself.
Must be the GIF, mine seems to work.....
Thank you.
If the GIF is too big of file, sometimes it will only capture the pic portion of it. This is the max allowed on the site for GIF's gif 78.1 KB, 620 width, 280 height. In your Control Panel where you switch your avatar, right click on the GIF and then properties, then look at the size of it.
If this is the .gif you are trying to use:
...then the filesize is too large for what this forum allows for avatars. The avatar limits are 160 by 160 pixels or 19.5 KB (whichever is smaller). Your image is 35KB.
That's the one. Guess that's why it doesn't work. Thanks for the help.
SO happy I have avatars disabled! Nothing like waiting for a bunch of gifs to load when I want to read a page![]()
User CP, Options. I have signatures off as well. Those options, along with ADBlock Plus, will revolutionize your forums experience.
