oh sh*t moments
chipper
Williamsburg, va
What's the biggest mistake you've ever done at work? I just bought a new jack and i couldn't help bought think about the time i was fresh out of vo-tech about 17 years ago first job and i jacked up a van on the oil pan....oh sh*t. i ended up staying there about ten years i would of fired me
91bronc300
I broke the bridge crane at a plastic injection molding plant one day while changing a mold. Nothing came crashing down, but it was sure loud.
firebox40dash5
How about joking about porking the boss' stepsister? Or joking about the time his friend porked his sister, and then joked about it? :lol:
But really... busted an ABS sensor doing a wheel bearing on an Infiniti FX, I usually leave them in doing unit bearings since a) they come with the bearing half the time and b) half the time they break if you try to get them free. ABS ring busted the tip on this one coming out. I'm thinking "It's Nissan, probably the same as an Xterra or Maxima or something, it'll be cheap." Nope, $250, dealer only. I went to the junkyard in the morning and had the yard guy drive me around to everything Asian I could think of, and not a single one was close. Bastids!
928'er
Wine Country, CA
I was converting a '82 928 to S4 brakes (Brembo 4 piston) and front suspension. While removing one of the lower control arms I managed to shear off one of the mounting bolts (grade 8.8, 13 mm diameter, ~6 inches long).
The car was up on jack stands and I had to drill out the remains of the grade 8.8 bolt with a hand drill while lying on my back, drilling straight up, with barely enough room to get the drill under the car - and see what I was doing. Think I still have steel shavings in my eyes.... Turns out the bolt was corroded about half way through - it's a CA car and that's the only corrosion I've ever found anywhere on the car.
Then there was the time (years ago) when my TR3 came off the jack stands and landed on the front brake discs - dodged a bullet that time....
bhalv
Boise Idaho
nearly ran our companies $800k aircraft into a customers 1.5 million dollar aircraft, yeah my heart skipped a few beats.
jmm
NC
Biggest mistake at my current job (overhauling looms in a textile mill):
I was putting in a new $500 reed (makes everything perfectly straight, and the yarn compact on a piece of cloth) on a loom. To set it up, you use a large straight bar to line up the left and right sides. I accidently left my straight bar sitting in front of the reed. Went to turn the machine over (not start it, just turn it over). It wouldn't turn over all the way, just stopped at a point. I took it out of gear, cut the power, and attempted to force the machine over with a break bar + cheater. At the moment when I'm leaning on that cheater bar about as hard as I can -- I see my straight bar bending the **** out of that brand new reed. Panic.
I got really lucky, because I was able to rig the loom to run with a bent reed. Cloth passed QC, and I didn't get written up. Amazingly that straight bar is still straight as an arrow.
C
chipper
Williamsburg, va
That reminds of a time i needed to come in on sat. to use the lift and friday eve the mech. told me he just did the brakes on the car that was on the lift so before i took it off make sure i pump the brakes...well i forgot i almost ran a dodge magnum through abrick wall
diesel research
gulf coast, TEXAS
removed a "piggy back" air brake chamber with full air applied on service side....air pressure released fast enough, creating enough wind to cut my hand open. very stupid mistake.
jamesc
Ontario Canada
i backed a car into a set of torches almost knocked them over scared me quite a bit. I had forgotten to pump the brake after doing a four wheel brake job.
Tunger
I was replacing an exhaust manifold on a gm 3.3l in a '91 buick century and long story short, I melted a hole in the fuel rail with the alternator power stud. What followed was a huge fireball and an engine compartment engulfed in flames. Luckily my best friend and co-worker was quick with a fire extinguisher. I lucked out and only ended up having to replace a fuel rail, alternator, and do some minor wiring repair. I did learn 2 important lessons that day; know the locations of fire extinguishers and disconnect the battery if you are gonna mess with anything with large gauge wiring or fuel near said wiring. I was pretty young and knew it all then, now I'm quite a bit older and know nothing, lol.
Sent from my GT-P3113 using Tapatalk 2
firebox40dash5
My dad did that to my mom's Impreza last year. He calls me and just says "I think I ****ed it up." He was replacing the headlight bulbs, and decided to remove the positive battery terminal first to remove it and get to the bulb. With an old 1/2" Craftsman roundhead, and a deep 10mm socket. :shocking:
Derp. #1: Negative comes off first, and goes on last. #2: When ignoring #1, do so with the smallest tool you own, not the largest, and put a glove or something over the handle. :lol:
chris142
apple valley,ca
My boss is the king of folding Honda hoods in half. he forgets to remove the prop rod first before closing the hood. I once smashed a Hyundai Excel door on a tool box while lowering the car. but in my defense it was the guy sitting in the car pumping the brakes fault. as he had the door open and I had to be on the passenger side of the car and 50 ft away to lower the two post lift
netcaretaker
Many Places, right now NC
Getting fired for being right.... The guy next to me was working on an international truck and thought the timing was off, rebuilt the card, pulled the timing chain, still could not get it to run. I had been telling him and the owner that you time an international v8 on number 8 all week. The owner called the international dealer and walked out and said, huh, you time those on number 8. I lost my **** and told him I had been telling him that all week, we got into a fight and he fired me, only job I ever been fired from and my Dad fired me.....(yes, my dad was the owner) LOL.....
bobcatdan
Kaukauna,WI
When I first started at bobcat, I didn't know all the the features on the machines. I was unloaded a bundle of new buckets off a semi with a skidsteer and as I backed away and lowerd the boom, the bundle slid off right into the brand new drivers tires on the semi, slicing them. The skidsteer had bucket postioning which keeps the bucket level as the arms rise, but does nothing when lower. As the arms come down, the natural motion puts the bucket in a dumping angle. I never even notice BP was on until it was too late. In the short time I had been there I had done some other bonehead moves and really thought for awhile I would be fired. Well I'm still here.
Nanashi
Checking rough idle with brake cleaner on an older vw jetta. The distributor cap was cracked, wooosh the whole motor went up in flames. I panicked and ran to my boss and I **** you not he looked at me calmly and told me where to find the fire exhaust as if it wasn't even an emergency lol. Nothing melted oddly enough I only had to Clean the motor.
uniballer
bedford, va
Burned down a Genie boom man lift. Too embarrassed to say how.
I got to here this!!!!
But I put a 1998 v8 6speed camaro on a lift at votec, raised it, walked away to get a tool and it slid off! Only had 350 miles, luckly it was a donation.
48Classic
Metro Atlanta
While working for a television production company, the big boss told me to pull the conversion van in a parking garage at a major hotel chain. We were doing a production inside the building, I told the boss the van would not properly fit. He insisted, after the production was over he grabbed a ride with someone else. Well backing out of the parking space I clipped the overhead fire sprinkler and flooded the deck and the elevators... Luckily the companies insurance paid the bill. Boss was fired!!!
chris142
apple valley,ca
All he had to do was look at the valve cover! It says "Time on #8" on both of them!
btbsandman
Missouri
While working at a pharmaceutical research lab I accidently poured their 30K drug concentrate down the drain. And the reason I didnt get fired is because I gave my 30 days notice a week earlier.
dleonard1122
New Jersey
While working on a brand new (2013, 5 hrs) jetski that was on a trailer, I was installing the battery in the rear compartment. The front of the trailer went up, back of the trailer hit the ground, and because for whatever reason I decided to loosen the winch strap, the trailer rolled forward leaving the entire jetski sitting on the concrete floor
RCP
Working at a Junkyard in the warehouse.
The way these guys had he warehouse setup was completely retarded. I was new on the job and had to get a pallet with transmissions on it down (it was a 3x5 ft pallet...). Well their homemade pallet broke into about 4 pieces and sent these transmissions on about a 10ft fall. Broke the bell housing on one. I was wrote up and told I either paid for it or I was fired, I didn't pay and I wasn't fired. After the fact the guys around the shop told me that they go through guys every four or five months because they refuse to admit it's their system and not the guy using it.
KinzeMech
Servicing the wife's Cavalier...didn't want to jack it up twice, and knew better than to jack it up by the oil pan. Put the jack under the transmission, and busted a chunk out of the aluminum bellhousing.
Drove it like that for years. Down the road, got the opportunity to have the transmission out while replacing the engine, so I took it to the local aluminum welder (had always kept the broke off piece). I gave him the transmission and the broke off piece, and he says to me "How in the world did you find that piece back?" ...
KMScott
I worked for a government out fit called N.C.A.R. as a model maker. One day the crib attendant asked me to weld his trailer hitch more secure to his frame during break, he was getting married and wanted his wife's car to haul his pull camper to Moab for his honey moon. The weld shop is 5 stories below this icon building in Boulder, designed by a famous designer from Japan 35 years ago and sits on a hill overlooking the city. The crib attendant did not tell me the gas cap was not the original and did not tighten like it should. As soon as I struck an arc I heard the ****, I raised my hood to see the tank expand and start blowing a stream of lit gas like a blow torch on the cement below it. I should have been killed. Why the car did not blow up is anyone's guess. In seconds the *** end was a blaze, I rushed into the drivers seat and started the motor and by then both rear tires have blown and smoke was pouring up 5 stories, I could not get the car all the way out of the garage. As it blazed the fire alarm went off so everyone poured out to the mezzanine one story above me and had ring side seats for this mess, I am guessing over a 1000 work there. Now these people are all scientist and PHD's and they were not going to help me put this car fire out. I ran in and out with extinguishers that I grabbed from lab after lab and before the fireman and cops showed up I had the fire out. All of this was captured on film. I did not get fired because I melted the clock at 10.05 am and that is our break time. Hence G-jobs. The one picture in the paper I remember was the cops and Fire Chief having their note pads open and me with my head down walking toward them with a dirty burnt shirt and pants. I'll never forget calling the crib attendant and not having time to explain to him what happened but wanting to know where to take his wife's car because the wrecker was in a hurry, he is a nervous kind of guy and was more of a mess then me. What I learned was to never weld something in a hurry with out really looking it over.
sgtmac
Wilmington ,nc
While in Boy Scouts getting ready to set up at summer camp. I saw an attractive lady and leaned over to my buddy and said to him " I wonder what her ***** looks like?".
About the time i finished my question I looked over and saw one pissed off Scout master steaming up the hill toward me. He hollered at me " That's my wife and I'm gonna kick your ***"!
I believed him and ran to my scout master and confessed what I said. Hoping he would save me from an un Boy Scout beating.
He told me to go hide and he would take care of it. Before he went to intercept the steaming scout master he looked over at me and said " he wondered what it looked like too"!
I lived.:bowdown:
wafrederick
Holton,Mi
I left a hoist arm underneath my father's toolbox and tipped it over.My father was not too happy with me.I learned my lesson,I now check where the hoist arm is now and it never happened again.Did damage to the fender of a Ford van.
91bronc300
I lived.:bowdown:
:spit: Good story :lol:
A_Pmech
IL
I didn't need to hear this.
:mad:
Guam_Guy
Ran a 180k main rotor blade into the side of a hanger. Brakes gave out on the 1500.00 tug...go figure!
mustanginky
about 3 years ago, i was a parole officer (now a lieutenant at a correctional facility), we were doing "night visits" on parolee's and attempting to apprehend fugitives.
we knocked on a known wanted felons door. when asked who it was we said "parole officers". the female said "hold on a minute." obvious stall tactic.
the police sgt we were working with stepped around to the back of the building to cover any escape route. sure enough, this recently released prisoner comes out the back door and proceeds to get into a fight with him.
we're on the front porch, hear yelling, and before we can get to him i see a man in under wear sprinting down the street. game on.
we chase him about 2 blocks and he rounds a corner. we take it wide. the others i was with saw another person running about a block up. i know he hasn't put that much ground on us but they go after some random guy running. i slow down.
he saw the other two sprint by him as he hid on a porch, and not knowing i was there, proceeded to sprint my direction while looking at them. i drew my weapon, what with a 210 lb fleeing convict closing in on me at about 10 feet, he see's me and turns a 90*.
as he runs across the street, we both run right in front of moving vehicles. damn close to being hit by a car, tires squealing and everything. tunnel vision got the best of both of us.
he trips on the curb, and falls into a row of bushes. me thinking i'm ray lewis, attempt to wrap him up while he's on the ground. i have no clue why i did this but i went full out dive to get on top of him. he rolls to his left and i am left trying to wrap him up while flying face first into some dead trees.
i eventually catch him though. while squad cars pull up sideways, and i'm cuffing him, i look up to my buddy and quote the movie "superbad" by saying "he's the fastest kid alive! he's the fastest kid ever!" i knew he would see the humor in it. who didn't find it funny were the 5 or so other police officers who were calling the pursuit off. me saying that was repeated to dispatch and echoed back through everyone's radio. i look up and see an extremely gorgeous blonde from the police department staring at me and shaking her head like i was some sort of fool. which i was.
there were several other "Oh sh*t" moments that happened, but that was my best/funniest one. nearly struck down by a car chasing a felon, then proceeding to make an *** of myself.
ZRX61
Solar Blight Valley, SoCal
Worked in the docks in the UK. We sent cargo to 3 destinations: Jersey (pink paperwork), Guernsey (green paperwork) or Spain/Portugal (white paperwork).
Had a refridgerated container come in full of meat. Bound for Jersey. 24 hours later no sign of the box in Jersey.... dock was searched in the UK, no sign of it... dock gets searched in Guernsey.. no sign of it.. no trace at all.. police are called, they think someone stole the box off the dock in the UK.
A month later someone followed the smell & found it sitting on the dock in Portugal....
kursplat
S.Cal
pulled a ground chain (steel rope used as an indicator that a high voltage electrical line is de-energized) over a hot 34500v line.
when the CB reclosed in the station, it blew the ground chain into about a thousand pieces............ i still hear that noise
