remodel time for my garage
32krazy!
after 7 yrs of jamming stuff in the garage its time for my first remodel.
the dewey , cheatem and howe shop will be closed for 2 weeks while i change the configuration and paint add cabinets and generally claen all the dust dirt bugs , spiders and grime off everything!
ill post more fotos as i go along.
thanx for watching and opinions welcome!:willy_nil
heres the normal disarray
32krazy!
started to move everything to one side to be able to clean and start painting
astroracer
Mid_Michigan
Looks good. I will be doing the same thing with my shop next week! Just think how much easier all of that moving would be with casters on everything... Just sayin'. :)
Mark
fflintstone
MOFnowhere Mi.
dowecheatem&how must be young and full of piss and vinegar. they way I move in the shop it would take two weeks just to paint what you did.
I am 3 years into my shop remodel.
32krazy!
i only have 2 weeks off to get this all done! top color going on today!
rmousir
looking good.. I'm doing some thing like that over the summer my self. I'll be watching how this goes. Thanks for sharing.
32krazy!
2 coats of the top color. i used behr paint and primer on the bottom, a thick well covering paint. went with glidden pro exterior semi gloss to get the color i was looking for. MISTAKE! goes on like water. 2 coats used a full gallon of paint. wont use that again. anyway i hated the color at first but after the 2nd coat its looking better. not the lambo orange i wanted but you cant get pearl in housepaint! :)
ordered a 5" yellow vinyl stripe and a 2" black stripe for the accents. hope they come in by the weekend
Grip Grip
Looking good. You've been very busy. I would have spent the first week off drinking beer and watching TV. :)
32krazy!
ok started the cabinet build. im no carpenter so dont laugh to hard! ill finish them up tues. this was about 8 hrs of work for me! :)
xDavidx
Paint is looking really good.
32krazy!
between working on the car and the garage i got some more done today. heres the main cabinet all framed up ready for shelves and some trim and slider doors.
the next pic is a 6" white vinyl stripe and a 2" black vinyl stripe that will get laid on the walls this week
looks like the top tool lid needs to come off but it will fit underneath! fridge is now accesable. beer thirty!! :)
NUTTSGT
Northern Central Ohio
I wouldn't take the top of the tool box off it is anything like Cman box. Once you take the top off, there will be no way to lock it up.
32krazy!
box hasnt been locked in yrs. everyone around me knows im armed and krazy!
actually the lid is hinged and then theres 3 sliding locks that are also hinged. i just popped the pins and pulled them out so the lid can stay
32krazy!
Ok made some progress in the garage. Cabinets are installed and filled, new cabinets built.(yes I know I need doors!). Mounted the max max motor and hyd res. on the wall and situated some of the equipment.
MAKING SOME MUCH NEEDED ROM!
32krazy!
ok who's bright idea was it to remodel a garage in the middle of summer? oh wait, it was mine!! DOH! its been brutal hot but im making some progress.
serviced the ingersoll rand 2 stage compressor. new filter oil and added a longer drain setup along with rubber isolators.
temp setup of my best find to date! 2 36" wide and 2 24" wide stainless steel medical cabinets for 500$ !! once i have the upper cabinets mounted ill build a counter for the lower cabinets. somewere between 96" and 112" havent decided yet.
i have 3 5' by 4' butcher block tops. any idea on how to best tie 2 of them together to get 112" span?
walls painted and striped. maxjax motor and hyd tank permanently mounted on the wall.
almost there!!
32krazy!
Also the car talk lawyers.
Looks really good. The only thing I would have done is add more light.
its on the list. 4 sets of track lighting going into the ceiling. just doing things in steps so i can still use the garage as i remodel. to much stuff to move it all outside
Kevin54
MEMBER EMERITUS
Urbana, Ohio
almost there!!
I would dowel the ends together and if you have a Kregs drill jig, drill them so you can attach some screws from underneath. Or it you have a router you can make a couple of pockets and pull them together. Personally I'd just screw them. But you want to dowel or biscuit joiner them to make sure they stay in line with one another.
BTW....I think the orange and gray look great together :thumbup::thumbup:
32krazy!
have made some good progress!! scored some stainless steel cabinets and built a 1.5" thick bench today. got the cabinets mounted up and working towards the finish!!
Grip Grip
It's looking fantastic! What have you got planned this weekend? I need to swap the water pump, install the thermostat you sold/gave me, and change out the exhaust gaskets. I haven't ordered the gaskets yet, so I'll do that now. I guess you'll likely be charging for the use of the garage now that's it all prettied up. :)
