let's see your craftsman block grinders
nine4gmc
Dallas
Are any of them commercial Bluebolt? I'm looking for a commercial with the rear facing dust shoots. It doesn't have to have the Crown, but you know I'd prefer it, lol.
fflintstone
MOFnowhere Mi.
are you keeping the plastic lampshade or the whole lamp? I would enjoy a lamp sans the plastic shade. heck the only one I have with the cover has a big chunk out of it.
don't hold your breath but my friend is going to cast the water trays out of aluminum when he ever gets a forge going.
bisley45
Rogers, Arkansas
just picked this on up for 60.00.. its my first block grinder hell its my first grinder at all lol
torqueman2002
SE Michigan
Nice grinder and stand. What HP and model?
But, .... :headscrat
"... hell its my first grinder at all ..."
What is that I spy behind the CM Block grinder, a home made grinder, wire wheeler, and buffer? ;)
That's OK, you're among friends here. I'd venture a guess most are multi-grinderists!
torqueman2002
SE Michigan
You probably know to wear safety glasses when using this guy.
Heck, these things have been known to come apart, I stand to the side and use factory eye shields and a full face shield.
I probably have an extra pair of factory eye shields that fit your machine, I/M me with measurements if you are interested.
rusty65
Pekin,IL
Here's a couple photos of my block grinders one is a Delco I hope it still counts :). And the craftsman vibrates pretty darn good so I'm waiting to make a stand and get good wheels.
torqueman2002
SE Michigan
That's the first Delco Block Grinder I've seen, cool!
Can you post some more pictures, including the label? I'd like to see the model #, etc ...
:rocker:
bisley45
Rogers, Arkansas
I got that thing about a year ago it is a home made buffer. does a purty good job but not much rpms.
It is model # 397.19430 1/2 hp
rusty65
Pekin,IL
Here are the pictures you requested torqueman. I got the grinder from my grandfather who inherited it from my great uncle mike who was a big tinker. And it does run as good as it looks.
torqueman2002
SE Michigan
Man that is nice, and the color! Looks like original paint too. Is it?
Have you bee over to OWWM.com ? (Old Wood Working Machines) Their site has MFG info. with model numbers and mfg. dates.
IIR Delco was a supplier to Sears for the Block grinders, this sure looks like the spitting image of CM Block grinders.
There's a lot of family history there, makes it all the better. :)
I have a small handful of my dad's and his dad's Craftsman tools. They are retired wall hangers now.
torqueman2002
SE Michigan
That home made buffer should be good for low speed buffing, I don't know much about actual buffing. That's the next endeavor - turning a block grinder into a buffer with arbor extensions.
BTW - welcome to the Block grinder crowd. What prompted you to get one of these commonly over looked machines?
rusty65
Pekin,IL
Yeah the Delco has original paint my uncle mike kept things very nice. Most all the tools they had came from sears so he must have figured out that Delco made the grinders for sears and the funny thing is that my uncle mike was known for cutting grounds off power tools but on this one he put an adapter on the plug so you could put a ground directly from the plug on the outlet.
Mickey O
Chicago, IL
I have a few of those block grinders, they seem to multiply. Picked 3 keepers, the rest will hit craig's list.
Cranehead
Portland, OR
Becoming a Blockhead:
All the parts are there- model 397.19580 from 1964. It came out of an old gents attic, his grandson was selling it on CL. He had been a lathe operator at a local shipyard and made jewelry at home. I include the carpet that was on the bottom of the grinder- it shows its vintage. What made me drive across town in rush hour traffic though was the extras:
All manner of buffing and grinding wheels and compound. Lots of sanding disks and emory paper too.
The grinder never was fitted with the light. The hole was never punched out for it or the water tray. Has anyone retrofit a light to one of these?
Seeing the beautiful restorations of these makes me want to do the same, but since its running smooth I'll just put it to work.
tc
torqueman2002
SE Michigan
tc
Congratulations, nice grinder.
'Blockhead' !!??!! Well now, I resemble that remark. I even added a picture to my profile and signature just now. :thumbup:
To fit a lamp like the following one, connect the neutral (white/ribbed) wire of the lamp to the neutral (white/ribbed) wire inside the grinder, and the hot (black) wire to the hot (black) wire inside the grinder; alternately, connect the hot to the controlled side of the power switch. That will turn off the lamp with the power switch or you can turn it off at the lamp (the switches will be in series, both need to be on for the lamp to turn on)--> http://tinyurl.com/ka87ssb
torqueman2002
SE Michigan
Yours is much better looking than this Delco grinder--> http://tinyurl.com/Delco-Red-Block-Grinder
Thumper68
Duluth MN
Here's one I picked up 20 years ago, been working hard in my shop since I brought it home
Just did a little refresh on the ped, the light and the safty glass it was so bad that it couldn't be seen through anymore.
WarrenP
Toledo, OH
Here's mine after cleanup and rewire. Still mulling over whether I want to completely remove the wheel guard on the wire wheel side. It is complete except for eye shields.
A bargain at $15.
bisley45
Rogers, Arkansas
I have always liked the look of the craftsman block grinders. they come up for sale in my parts every now and then but you would think the windings in them were made of gold instead of copper lol. I got this one at a very reasonable price had to by the whole shop almost.
K Powers
Alabama
almost done with it, 1/4hp split phase, now need to start on the stand
torqueman2002
SE Michigan
I'm making progress on Big Blue. Here's the tested [for broken internals], cleaned and painted rotor.
I also tested the Stator & Coil assembly [high voltage surge test & high pot test to ground].
I found a place that has many of the Block motor grinder parts I didn't expect would be available (including some of the cast parts and labels).
More info:
http://tinyurl.com/Big-Blue-Rotor-Shaft
http://tinyurl.com/Block-Grinder-Info
:rocker:
torqueman2002
SE Michigan
Yea, kinda forgot about where the bearings seated. Should've masked it off. :wtf:
Did some judicious clean-up of those areas and the snap-ring groves before the bearings were fitted.
torqueman2002
SE Michigan
I had to take a couple of steps back; but making headway on the Big Blue Block grinder rebuild. Got it assembled, tomorrow I'll terminate the wires and hook them up.
Brian K. @ OWWM says he thinks it is: ".... last of the Delco built machines, model number 397.19450". I found an eBay listing that gives this info: "SEARS Craftsman Commercial 3/4 H.P. Bench Grinder/Polisher, Totally Enclosed Ball Bearings, and Capacitor-start motor, Specs = 115/230 Volt, 60 Hz, 6.0/3.0 AMP, 5/8 arbor, 3580 idle RPM, NEMA rating, ship wt about 26.2 lbs."
Here's the improved Big Blue; dare I say: M-Go Blue! ??
I need to decide what to put here; I may turn this into a Block motor Buffer.
Here is the final version, with wire wheels.
I'm adding fuses to protect the stator windings from sticking start-relays. This one uses a Slo-Blow 15A.
At speed - it pushes a LOT of air around the bench.
Here it is the the growing grinder-row.
KerryH
Ga
Jeez, adding yet another item to the list of tools to look out for.
This forum is the best thing that's ever happened to my shop and the worst thing for my wallet!
torqueman2002
SE Michigan
I hear you!
Look at it this way - the $$ you save restoring or putting a good used Block motor grinder into service vs. a similar new grinder (Baldor, ...).
But, don't follow my example; I don't want to count the number of Block grinder around the house.
My wife just laughs now. :D
flashman
Niceville Florida
I just picked this grinder up today. I would have preferred a higher HP but I think 1/3 HP will be good. I assume it would be comparable to my Porter Cable 6" grinder I purchased from Lowes a couple of years ago.
For the power cable, would I be better off buying a new cable and replacing this old one because of the sheathing that is pulled away? Or would this cable be salvageable? I also will either have to have the glass replaced or find a replacement guard but otherwise this is in good condition and it spools up nicely. The bearings are still spinning free and smooth.
Sent from my DROID RAZR using Tapatalk 2
E
emeraldcoupe
spring hill, florida
that looks great in blue
