osu69
North Georgia
Re: what did you do in your garage today?
Finally replaced the carb on my Stihl 028 chainsaw. It's been a difficult lesson to learn that some things, like 24 year old carbs, just can't be fixed. Runs great.
In My Garage
ON
Topped up the AC in my car a tad, but ran out of R134a due to the can being near empty to start with. Indications are at idle RPM; low pressure drops to under 10 psi off idle.
1995%20Porsche%20993%20-%202013-07-13%20-%20After%20Further%20Recharge%20-%20Idle-L.jpg
I finally got to use my gauges.
Cool eh!
IONH
Central Massachusetts
J king
Ne oh
Last week I replaced the engine on my mower.Changed brands with a efi engine.Lot more power now.Today I pulled motor out of daughters car to replace it.She cooked it..Shame too.car had 60000 miles on it.grrrrr...
Doug Arthurs
Ontario
I finished milling these riser blocks for a customers project this morning.
patrickn
State of Confussion, somewhere in Indiana
Okay Kevin54, here's the emblems I've been restoring that I mentioned a couple days ago for a Pennsylvania customer with the Dodge 800 truck his grandfather bought new. First, a few "before" pictures of what I started with ...
And here they are now ... far from perfection, but they're a lot better.
Kinda cool to see the "before" and "after" all in one photo!
I used the group pic on the left while I was working to make sure I got the colors in the right spots ... and then decided to just put it on top of the finished emblems inside the shipping box LOL
If you're on FaceBook, I have a regular feature on my shop's Fan Page called the Friday Powder **** where I show off the preceding week's work. Here's a link if anybody wants to check it out, send a Friend Request or Like the page.
Have a great weekend ya'll! Stay cool, stay safe, and above everything else, keep your powder dry. :D
Those are outstanding! I know when a person works on something they always nit-pick it and it just isn't 100% perfect to them and sees little flaws(I am the same way) but these look awesome!
If I was that customer I would give you a 5 star rating! Good job!
I'm going to your FB page in a few minutes.
Good job!
3798j
Susquehanna Valley
This morning changed the oil & filter, lubed the suspension, then did a general detail on the TR4A. Followed it up with a drive in the country.
patrickn
Very nice car! Looks awesome. Hate to admit it, but had a TR7 (had a good time restoring it and fun driving it). Sold for a very good profit.
Nice garage setup too!
trbomax
starvation lake,mi.
Yesterday I got 3 of the 4 colums for my little 1 t bridge crane extended and new base plates fitted. I had this crane at the front end of the rotary at the old shop for 20+ yrs. The cieling in that part of the shop was only11'-6" so it was built to that size. Up here I have almost 14' so I'm adding 18" to the colums to take advantage of that. In the old shop the lift and crane setup was used mostly for pulling large frp parts out of molds,and setting bare boat hulls on newly completed trailers. I dont think I had more than 2 or 3 cars on it in the 20 yrs it was there!
I'm going down and try to work on the 4th colum in a while but its 88 deg@ 90% humidity,so it likely wont get done today!
Outlander
Quebec, Canada
Stayed in the city (therefore workshop rather than garage) and worked on repairing the fence & gate, taking a couple of trips to the dump. etc. "supervised" the contractors replacing a fence on one side, "supervised" my 25 year old daughter and her friends borrowing the pool. Still managed to slip in a round of golf :)
jshultz78
I finally fixed my driveshaft issue. Ever since I did the v8 swap in my extended cab s10, I used a one piece drive shaft, and it has been hitting the bottom of the cab, so last night I ran across the old piece of roof that I saved when they put the sunroof in, so I decided to use that for a new transmission/driveshaft hump.
First crappy job done 2 years ago before I got a welder, just notched it where I thought it was hitting, and had screwed some pieces of sheet metal down to cover the holes:
After about 3 minutes with the trusty ol dewalt jigsaw, you can see where it was rubbing:
Finished welding, I didn't worry about grinding any of the welds down since you won't see it from the carpet, but I did put a coat of primer on so it wouldn't rust.
All in all, I think it turned out ok, had to play with the welder settings alot, and getting the gun angle right. :drinkup:
Lugnut30
MN
Did some planning for next project then sat and had beer....
saigashooter
I changed the front and rear diff fluids, and engine oil on a 97 Yamaha Wolverine. Now if I could just figure out why it dies when giving it full throttle. Time to pull the carb again I suspect.
where2
South FL
Put anti-seize on the 72 mounting brackets that hold the 20 solar panels on the roof rails, and torqued them all to manufacturer spec, without falling off the second floor roof.
Pulled out the Dewalt mitre saw and cut more romex support strips for the wiring in the attic. Once it started raining, I headed for the attic to install the support strips and tacked the romex to it.
jshultz78
Check the boot between the carb and cylinder, I had a warrior with the same engine once, and it had a big crack in the rubber boot, sucking too much air and running lean.
saigashooter
Actually I looked at that, boot was a bit ****-eyed on the front of the carb, re-seated it, problem persists. Idles better though, now if only it didn't feel like it was pulling a boat anchor at low speed and want to snub out at more than 30% throttle. Last year I replaced the diaphragm in the cab as it had a pinhole in it, it was better after that but it seems to have gone south again.
IONH
Worked on the DIY recumbent bicycle for my wife today for a few hours. Finally started cutting up the old ones, used a hole saw set from HF on the bicycle frame tubing and was surprisingly impressed and also ground down some of the pipes that I cut off and won't be reusing the location.
jshultz78
Since it's boggy and won't rev, check the spark plug, I had an issue like that with my banshee about 2 weeks ago, forgot to take off the airbox lid, so it was WAY rich, got about 500ft. down the road and fouled both plugs, it barely ran, and wouldn't rev past about 1/4 throttle, swapped the plugs and ran like a champ.
ABADWILLYS
Hudson Valley, NY
gutted my race car to repaint the cage, years of getting in and out and seat belts dinging it all up, it was looking shabby, i dont know if anybody has painted a roll cage but it is a major PITA! have to weld new window net mounts on because im changing that too, spent quite a few hours just taping the inside of car as i only want to paint the cage, and got some sanding of the old paint done.
jrg
Seattle, WA
Installed my $100 craigslist interlocking garage floor! Now it needs a good clean.
Rewind97
Mississippi
Got it wired for internet connection!!! I was too far away from the house to pick up the wi-fi from the house so I had to run a network cable to the shop. Been wanting a computer out there for years. Got a buddy to come help this weekend and Got-R-done!!!
911mike
michigan
Finished the tin ceiling in the shop this weekend. I was a little worried about installing the 23' long pieces by myself, I won in the end!
View media item 31744
Finished:
View media item 31745
I feel like I got my *** kicked, Not as young as I think I am!
I'm not looking forward to doing mine. How did you keep all the screw straight and in the narrow 1.5" wood rafter? Any tips? My trusses are 44 ft and they just have a natural wave to them. When I did the walls we ran a rotating laser which was really nice for shooting in the screws nice and straight.
Thanks
trbomax
starvation lake,mi.
Thanks
On mine I screwed a 2x4 to the bottom chord.This gave me 3". Make a drawing of the bottom chords useing the joint between the bottom chord and the 2x4 doubler as the c/l. Stack your sheets,transfer the measurements to the sheets,and drill all the holes at one time. If you find that you are running off the bottom chord with the screws,just add another 2x4 to give them something to hit.DO NOT run the screws with an impact driver. The hammering will chip the paint off of the screws and will look like ****. Use a cordless drill-driver and ease the screws in,useing the clutch release to eliminate overdriveing.
wrench409
Over here....
Today, it's raining, so I called my BIL and had him come over for scrap. He can use the cash since he's not working and when he left I found.........
a floor!
Then I adjusted my garage door rollers/panels to tighten them up in preparation for new door seals to keep out the dust.
This old garage has NO ventilation at all. No ridge vent, no eave vent, no soffett vents, zip, nada, zero. I gotta get this heat outta here in the summer.
What to do? Ahhhh that's for another day.
JimVonBaden
Northern Virginia
a floor!
My NEW garage came the same way. Sheet rocked in with NO attic vents whatsoever. It is an over in summer. I need to do something with it.
Jim :cool:
NUTTSGT
Northern Central Ohio
Put in some soffit vents and a ridge vent up top. :thumbup:
