I did this same thing two weeks ago.
First, you have to list your needs and priorities, and then BE REALISTIC!
Yes, I'd love to have the 230V made-in-USA 1960's type all iron, kick ****, no-holds barred air compressor that looks like it could flow 60 CFM easy.. But let's be real....
I NEED a compressor that will run:
My air tools, including some small grinders, tire fillers, a blower, a DA sander, a cutoff wheel, maybe an impact wrench or two, some cool little what-nots and my cheapo paint sprayer. There.
I NEED it to work in my garage, which at this time means 120V, a 30 gallon tank would be OK. I wanted an oiled pump, and had to have, I thought, between 5-6 SCFM, with 150 PSI.
I don't need THE BEST, but I'd like one to do the above.
My three choices:
Husky 33-Gal. Portable Electric Air Compressor
Model # F3S33VWD
Kobalt 1.6-HP 30-Gallon 155 PSI Electric Air Compressor
Item #: 221495 | Model #: LLA1683066
Craftsman Professional 27 Gallon Vertical Portable Air Compressor
Sears Item# 00916474000
Well, the Husky went first, oil-less. Haven't heard anything good about the oil-less compressors. Out
The Craftsman looked good, had pretty good numbers I thought for me and what I needed, but I just wasn't sold on it... And I am a Craftsman guy...
So, the Kobalt went home with me... I liked the three year waurentee, I liked the extension for $49... It seemed right
-6-HP 30-Gallon 155 PSI Electric Air Compressor
-Cast iron, V-twin cylinder, oil-lubricated pump features 1-piece cast iron crankcase, thermally stable cast iron cylinder body, aluminum head and machined cast iron valve plate, automotive style ball bearings, and durable stainless steel reed valves
-Heavy-duty induction motor for maximum performance and efficiency
-Fully assembled 30-gallon ASME tank with pre-attached pneumatic wheels, quick-set regulator, tank and working pressure gauges, quick-connect air outlet and on/off switch for ease of use
-155 PSI max pressure, 6.2 SCFM at 40 PSI, 5.3 SCFM at 90 PSI, 1.6 running HP
Hehehe, now, after a week of use, would I like the bigger 60-80 gallon tank and 230v? Of course! Also, this and several of these tanks have really CRAPPY drain placements, so build yer own with some stubs and some ball valves. Trust me here....
It moves around a lot.
I am gonna get some anchors, and also maybe some plumbing for some permanency. Anyone know how to set up a compressor?? (I'm kidding...)
Long and short, figure out what ya NEED, and go for it. I heard what everyone said about "Buy it best and buy it once" la-la-la 230v la-la-la but it just didn't work for me.... Maybe some day!
