What's wrong with this picture?
e-tek
Saskatoon, SK
CAOS
Land of Living Skies, Canada
The only thing that concerns me is the aerosol can arcing out somehow and exploding. Everything that needs to be is covered from the uv rays. The filler wont get that hot.
zkling
Body posture, most definitely. That does not look like a comfortable position to hold for long. OSHA would not approve. Other than that I see no issues what so ever. :D
Iron Cat
NY
this ^
bullnerd
Jersey
S#!T, thats a safety poster compared to some of the fab shops I 've seen. Ones where the work comes before all else.
NASTYZEN
St-Colomban,Que. Canada
He's not holding the torch within the 15 deg. true to the part. With that much angle you start to draw in to much air. You get contamination and your weld is harder to make pretty. Looks like Stainless as well, would get even better if he purged the tubes from the inside.
The paper and spray can are a little close... ever press on the nozzle while welding.:yikes: nearly shat myself.:)
LXCam
He has one of the EGT bungs upside down in the table, that's sure to screw him up. :p
rodknocker
Rochester,NY
The little TV on top of his tool box is turned off, and he'll never realize how the nation feels about the Zimmerman trial.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Too much flammable **** laying around, plus whoever is taking the picture is more than likely looking at him welding without having eye protection
