I'm trying to remove the hub from an old, large tractor loader (a TractoMoto TL-10 if you know about such things).
I got the wheel off with a 4 ft pipe wrench, a little heat, and lot's of pb blaster. not sure which of the above did the trick.
I am now trying to remove the brake drum so I can replace a wheel brake cylinder. I got one side off and repaired without a great deal of difficulty so I know what's under there. the other side is stuck. The axle is about two inch diameter, and the surface I can pull against has a 14" diameter. I've got my third puller on the job and it is the right size (at least it fits). It is an OTC 17" 13 Ton Mechanical Grip-O-Matic Puller. This is my third puller in the series of purchases to try and get this off. If you're not familiar with it, it is a $200 variety three legged puller. Good stuff. And I still can't get this to budge.
There are no snap rings or such and the brake shoes are backed off. I put a 1/2 impact wrench to it and still no joy. Lots of PB Blaster. I tried heating the hub w/ mapp gas affair. won't seem to budge. The hub is pretty massive - perhaps 1.5" thick right around the axle. I have a oxy/acet torch I could use for more heat. there are no bearings or seals (they are further inside the whole affair - recall, I've had the other one off.
I've attached a photo to show the affair.
This equipment is well made and meant to be repaired. It's just that it hasn't been for about 50 years :=)
Suggestions for next steps greatly appreciated.
