Corded drill recommendation. High torque, High speed VSR
sbarton
I need a corded drill to operate EZ Car Lift.
Needs to be greater than 8 amps, dual speed, infinitely adjustable from 0-max RPM (new Dewalts start at 500rpm and won't go slower, just shut off). Would really like keyless chuck.
The more powerful the better, the faster the better. I want to be able to raise and lower the lift quickly.
Around $150 or so.
-Scott
rancherbill
Foothills County, Alberta, Canada
I wouldn't buy the bosch. I have had three of them that have burnt out the power switch, while running them at half speed.
The specs you have are hard to meet. If I were you I'd find out what they were using in the video. If you can't find it , them I would get a Makita - they are professional quality tough drills.
DeliveryGuy
Dartmouth, Nova Scotia
I have the Makita DP4010. I don't see it on the US Makita site, but there are similar drills.
Its got tons of power, and will set you on your **** if it fetches up. I drill 1/2 holes in heavy steel with no problem.
LXCam
The problem you got is looking for a 1 hp drill motor with a variable speed trigger that will last. I've never found one worth a ****. I'd suggest a Milwaukee hole hog, it has a two speed gear box and will handle what you wanna do with ease. GL
LXCam
I suspect that lift was meant to be hand cranked, 350rpm is several times what you can do by hand. Besides what does it matter how long it takes to raise/lower?
It needs rpm for sure. You'd be cranking for days with a ratchet :(.
JJThrasher
Indiana
I'm wondering how long it would take to get the car up with 850 rpm.
Their site claims it can lift to 26" in 90 seconds. A review of the lift said it took just under 2 minutes to lift a car to full height. Neither mentioned the rpm of the drill used though.
CWP1616L
USA
My 3/8'' drive Bosch will put a 1'' auger bit through a 4X4 doug fir no problem. I'd imagine the 1/2'' drive Bosch is a stump puller.
