I’m in the process of wiring up some Bosch relay sockets and ran into a problem with the crimp terminals. The terminals are basically a female quarter inch push-on terminal with a tab on the back so they will slide into the socket but not come back out. It’s an open barrel terminal sort of like a Packard and thus requires a special crimper. I bought the econo line Sargent crimper thinking I could get by since I was only making a few crimps but I simply can’t get a decent crimp no matter how I do it.
I gave up on “practice” crimps since I was running out of terminals and decided I would solder after crimping but even that’s not working out. The terminals which I thought were tinned copper seem to be totally repellent of solder. I’m using rosin core, definitely hot enough, but the solder just beads up. Since these are crimp terminals and not intended to be soldered I’m now wondering if it’s not tin or there’s some other film on the tin that keeps the solder from wetting the surface.
Hoping there are some soldering experts here than can help.
Yep, I am **** about wires coming loose.
