What color T8 bulbs?
spotco2
NW Georgia
Working on lighting up a 30x30 shop with 10' walls and open ceilings. The walls will most likely have OSB covering them when finished. The floor color has not been decided yet.
This will be used for light mechanical work, but mostly for storage.
I've decided on going with either 6 or 9 4' T8 hanging fixtures evenly spaced with 2 bulbs each. I thought I wanted Daylight bulbs but looking at the lumens, it looks like some other colors have more than the Daylight.
What are the drawbacks to using one color over another? Is one brighter than another? I don't want to walk into a tanning bed when I go out to the shop, but don't want to have to use a flashlight to walk around either.
What is everybody else using and what do you like or not like about the color of your lights?
Highbeam
Mt Rainier foothills, WA
Color is one specification, and lumens is another. You can have dim or bright with soft or bright tubes.
I don't like the blue light of the high color tubes so chose the neutral 4300k which have been fine. You get used to whatever you choose.
spotco2
NW Georgia
I did not know the daylight was that annoying blue color. Which one is pinkish? Don't want either of those.
Black could be cool...
Joe G.
Indiana
Learning something new about lighting tonight...been rather enlightening :D
Sounds like I am looking to stay in the 4000k zone according to this site
http://www.buylighting.com/T8-Fluorescent-s/105.htm
IMO good choice. 4000-5000k is "cool" enough to give the appearance of the bright-white light that you want in a shop, while not being too "blue" that the daylight (6500k color range) gives.
Warmer tones are good for offices, retail, commercial space. Not so much for a shop even though a 3000k T8 lamp will have the same lumens as a 4100 or 5000k T8 lamp. The human eye, especially as we age, will perceive that cooler/whiter light as brighter, even though a light meter would tell you it's not so.
Nick_Wa
Northwestern Ontario, Canada
I went with the daylight bulbs and although my lighting is not finished, I love how bright it is. I'm not sure what is so bad about the color being slightly blue?
Sent from a Galaxy Nexus in Canada.
Random Guy
Daylight bulbs tend to look bad if you don't have the space lit brightly enough. Likewise, warm bulbs tend to look bad if you light the space brightly enough.
Banjorear
Essex Co., NJ
I've also been happy with the neutral T-8's.
hh76
NE Wisconsin
4100, or 5000. As long as you do them all the same, you won't know the difference. My general rule of thumb is darker walls/décor, whiter lights.
Keep in mind that lighting color is mostly opinion based. Plenty of other things to worry about, no use stressing about if your lighting is too blue, or too orange.
spotco2
NW Georgia
Just picked up Phillips F32T8/TL850/ALTO II Natural Light 5000K 2850 Lumen 10 packs for $7 each.
For the price I couldn't NOT buy them.
I guess we'll have Natural Lights in the shop now. My Miller Lites in the fridge might have an issue with it, but they'll just have to get over it :)
Speedy Petey
NY State
I use F32T8/741 for almost everything, even supermarket cases. Not pink, not yellow, not blue.
My customers love them.
2ManyProjects
Are you planning to paint that OSB? Or will you leave it more-or-less in its natural state?
Also, by "open ceilings", I presume you mean that the joists/rafters/trusses will be exposed, as opposed to having a flat (drywall or similar) ceiling. Is the underside of the roof itself insulated? And if so, with what? Some types of insulation have white vinyl backing, while others have brown kraft paper; this WILL make a difference in both the perceived brightness and color temperature of any reflected light.
Will the fixtures themselves have any sort of reflector? Or will they be bare-tube types or only have a smallish diffuser?
If this is indeed mostly just a storage space, I would urge you to split those fixtures onto at least two separately switched circuits. Figure out the minimum you can get away with for just casual "walk through" lighting (I'm guessing maybe two fixtures, three at the most), and put everything else on a second switch which will only be used when you are actually doing something important out there. Having to switch on up to 18 F32T8s just to go grab something from the storeroom is a horrendous waste of power -- not to mention that it's often the start/stop cycles which take the greatest toll on bulb/tube life; so sparing "most" of them that frequent torture will reduce your costs over the long haul.
If so, that is at least mostly coincidental. Color temperature and output lumens are two different things, and neither directly bears on the other (at least not to any significant degree). Also, don't get too hung up on relatively minor differences is specified lumen output. First, +/- 15% or so is effectively nothing. Second, the specs are always for INITIAL lumens; the actual output WILL diminish significantly over the bulb's/tube's life.
As noted above, splitting the load onto at least two switches will give you the best of both worlds, AND allow you to be a little more generous with the total number of fixtures (so you really will have plenty of good lighting when needed for any detail work) without having to apply sunscreen just to fetch a screwdriver.
This is PARTIALLY a matter of personal taste, which is part of why you're getting answers which are all over the map. Some folks prefer a "warmer" light, more like what we are all long-accustomed to from incandescent interior lighting, while others prefer a cleaner/purer white. But whatever you choose, note that the color of the various interior surfaces will also have an effect. Unpainted OSB, for example, will reflect the red/orange/yellow portion of the spectrum more strongly than the blue end, thus making the overall lighting appear somewhat warmer.
+1
4300K is actually a fairly warm white.
This depends somewhat on what you call "Daylight".
I've spent 40+ years as a semi-serious amateur photographer; now using digital almost exclusively, of course. I can tell you from experience that during the routine post-processing tap-dance, the one thing which virtually ALWAYS needs a bit of tweaking, even on those shots which are otherwise just about perfect in every way, is getting the White Balance right. This is especially so for shots taken outdoors, because the quality of that "Daylight" can vary so markedly. On those classic bright and sunny days with a clear cloudless sky, the ambient light will usually be around 5,500K or so during the middle of the day; becoming progressively warmer (i.e., lower color temperature) at lower sun angles. The hours immediately after dawn and immediately before dusk can produce light with color temps below 3,000K. OTOH, if it is even a tiny bit cloudy/overcast, the ambient color temperature can easily exceed 6000-6500K; and in deep shade, you can approach (maybe even exceed, in an extreme case) 8000K. Our eyes (and brains) are naturally adept at compensating for these color shifts, at least when they're in the context of natural full-spectrum light, so we tend to not notice them under "casual" circumstances (the trained photographer, OTOH, makes a point of noticing). But the same cannot be said for artificial light sources, in part because at least most of those artificial sources are NOT even close to "full spectrum". Which brings us to...
The other thing to remember here is that the "Degrees Kelvin" color ratings do NOT tell the whole story. That number defines the balance between the two extreme ends of the spectrum; but it does not address what's going on throughout the middle of the range -- and that can (and will) vary WILDLY with different light sources. It is in part for this reason that NO fluorescent light will be all that good at color rendering, as they all tend to have an excessively strong green component. So if you are painting or doing other color-critical work, you'd be well-advised to use some completely different type of light source in the first place.
Personally, I would probably go for a fairly "cool" light source for your application, in part because of the expected warming effect of those OSB walls. But if you really want to do it right, at least paint those walls bright white, and perhaps put up something white (large sheets of Tyvek, maybe?) above the fixtures to help moderate those reflections. This will help ensure that the reflected light is at least nearly the same color as the direct light; and that in turn will make things easier on your eyes in general. And of course, it will also make the lighting more efficient, as you will get more overall brightness out of fewer/smaller fixtures.
spotco2
NW Georgia
Thanks for all of the info 2ManyProjects.
Fixtures have been hung, bulbs have been bought.
We'll just have to see where it goes from here. It's going to be another couple of weeks before the power company gets the meter hooked up.
Joe G.
Indiana
:dunno:
Yes it's closer to the classic "warm" color temps of 2000-3000k, but it's not "warm" in that it starts to really bring in the blue (especially when talking fluorescent phosphor mixing) and rely less on the red/yellow's... though the spectral power distribution for fluorescent's are very poor as you can see (basically a few spikes of the main colors, with a bit more blue for the "cooler" colors).
There's also that photopic/scotopic debate... but I feel we'll just turn this into a REAL snooze fest for most here. :lol:
DekeT
USA
I could not decide on this question so I used a variety of K-values for the 20 or so bulbs I have in my shop.
marsh1
Texas
I went 6500K with my new fixtures and the results are outstanding. The purpose of the extra lighting is for car detailing. I can finally see the fine details and swirls marks that used to get missed.
MN4x4
Minnesnowta
I personally do not like the 4300K 'Warm White' bulbs as they seem to lean too much toward yellow. I find the 5000K-6500K to be just right. However, I am also no longer 21 :) so I prefer/need more light for whatever I am doing.
