WarrenJ
Re: what did you do in your garage today?
Nice work on the grips. Never have liked smooth finished grips.
Needed to clean up some space in the garage as I don't think I was utilizing space very well....wasn't sure what I should do and I found this site. Got some ideas with building a bench type unit and putting the tool boxes in it...so i went at it.
This was my first time working with wood. I went and bought a compound miter saw (cheap 10" ryobi...did the job perfectly fine)...first time using a compound miter saw. I wanted to put each tool cabinet on each side...but...I measured once and the right side wouldn't fit. I was about 1/2 inch too small. I guess it worked out ok.
Anyhow...I guess it turned out OK. If you guys have any recommendations, I'd love to hear it. I want to build another one where everything is perfect fitting...but wood wasn't straight when I got it from Lowes.![]()
Returned to the house at 2100.Needed to clean up some space in the garage as I don't think I was utilizing space very well....wasn't sure what I should do and I found this site. Got some ideas with building a bench type unit and putting the tool boxes in it...so i went at it.
Looks like a good enough job for your first. I've got a few suggestions for future benches if you are interested.
Wood from Lowes/Home Depot is never straight. Never has been, and never will be. And if it ever is somewhat straight, it will move once it dries.
Wow, let me guess, you also only buy american because others will break before you get home, right?
It is pretty widely known that dimensional lumber from the big box stores is still pretty wet. Wet wood moves as it dries. That's why it takes forever to dig through a stack of lumber at lowes/home depot to find something useable.
Yea. I seriously felt like I was going to drop the gun at any time. Nice sharp checkering is key. And I must say... after using the CA Glue technique on the checkering, these grips have some serious bite.
here is the finished product...
looking forward to an extended week end though and quality time in the garage Yea. I seriously felt like I was going to drop the gun at any time. Nice sharp checkering is key. And I must say... after using the CA Glue technique on the checkering, these grips have some serious bite.
I picked up a new tip on restorations, painting raised and indented numbers, letters, etc. For indented items use a crayon. Rub it over the surface until the grooves are filled, then clean off the rest. Supposedly, the crayon will stay for years to come, but I put a clear coat on top to seal it in. The excess crayon was a little tough to clean up and although the pic doesn't show it, the surface was left with a slightly dark residue. Not bad for a first time...
Craftsman saw Mitre guide
