The VISES of Garage Journal
Outlaw
Wouldn't building the Reed base on a CNC be easier, less setups. I have to make a couple of bases for my 2-1/2 Wilton's since I can not find any and the Wilton's are at about 5 degrees on the sides with a radius on the top side every where. Gonna have to cut out the pads some how and will end up on a milling machine eventually. I am anxious to build one but to busy now.
Kevin
Sure but the ratio of manual lathe owners vs CNC Mill owners probably in the area of a 10-20 to one ratio? :dunno:
KMScott
One of my former employees has a labeled on my Rotary Cross slide Ed's CNC. A little trickier but a swivel base can be built on a Bridgeport type machine. Rotary Tables with cross slides are real cheap now at auctions.
oldldh
Fairhope, AL
And it's missing the pipe jaws...and they aren't cheap...
If it's a C-3 it weighs around 200 lbs...
ShadowRuleZ
Detroit
Another 1750 came home with me today, got a little caught up on eBay and probably paid more than I should have. It actually has the end cap though! And hold downs that aren't bent like spaghetti. I'm going to have to sell one of these, trying to decide if I should put the new jaws I bought in this one or not, the jaws that are in it are pretty nice.
ShadowRuleZ
Detroit
The difference between the jaws that are on there (bottom) and the replacement jaws (top) I bought is interesting. Still not sure if I should swap them out or not, any thoughts?
Jere
I am digging those lower jaws, they look like they should grip great. Just use some wood block if you don't want to mark what you are working on
CNGsaves
KS and OK
KMScott
Advance Auto using 'Wilton 2904110' as the search term.
These are the same jaws you see on e-bay from milexequipment, this is why I build jaws in my spare time.
The original jaws in the picture have the serrations machined to a point, I always thought that was to much. I like just a little flat on my serrations. But the hardness of the originals are 54-56 Rockwell and that is why they still look great after so many years. The jaws on top look like the serrations were stamped in a press before heat treating. At least I hope they are heat treated, being soft where a file will cut them is not good.
ShadowRuleZ
Detroit
I figured if I got the Wilton part, it'd be a decent piece. The only reason I was considering using them over the set that's in there is how aggressive the other ones were. However, they do have some age on them so they might not be as sharp anymore.
gearheadglen
North Jersey
Picked up a Monarch 411 off of CL
It is missing the pipe jaws. The jaw width is 3 1/2 inches and it weighs between 30 and 40 pounds.
Guy had it listed as a "vice grip". I called and he said it was huge, I got there and it was small by my standards. He wanted $50 and we agreed on $40. I was going to pass on it since it was missing the jaws, but thought it was pretty cool. I probably overpaid a bit.
EOC_Jason
Bentonville, AR
That's cool, I've never seen a combination Monarch before.
EOC_Jason
Bentonville, AR
Here's a treat I found last night while doing some googling...
In the American Machinist Book, Volume 50 they had a four page article on How the Reed Vise is Made!!! :willy_nil It does specifically mention how the jaws are tool-steel and cast in place.
https://dl.dropboxusercontent.com/u/10831967/How Reed Vises Are Made.pdf
I noticed a weird thing, I downloaded the American Machinist book last night from Google and it was a copy from Stanford. I downloaded it today on a different PC and it was a copy from University of Michigan... Same volume and everything...
Anyhow, if you have spare time I would highly recommend skimming through it. It's an old treasure trove of information. They have several articles on how the 155mm howitzer is made! :)
bl00
Chantilly, Virginia
Cool thanks! I have one on how Prentiss vises were made. If I e-mail it to you can you post it up like that one? It's a PDF, so too big to attach.
va.grouseman
Southern-Central VA.
Hats off to the historians. Everybody benefits from your time and efforts gentlemen. Not to leave anyone out, there are several fine historians on this site. You're are like the scribes of old, writing and rewriting the pages of history, which at any given time were only one generation from disappearing altogether. You preserve the knowledge of a time when it was quality not quantity was the goal. A time I am afraid is considered antiquated.
Hot Chop shop
Las Vegas
Just finished painting my new Columbian vise 203 1/2 m2... Wanted to do the letters in red but the red i got was more pink sooooo...went with white...
I like it a lot but I might keep it for my future welding table build... The hunt continues for a big Wilton bullet to mount on my main bench... Hard to find on my craiglist here locally I always get beat out by other GJ'ers...:beer:
Hot Chop shop
Las Vegas
Pic came out weird using my Ipad to load it..I'm such a noooob:eyecrazy:
KMScott
Thanks again jason and bl00, this is very nice. Thanks guys I really appreciate these articles. Check out the large broaches used to form the square pocket for the movable jaw, imagine how large the press were to push that cutter. Look how they used rotary tables for the swivel jaws and swivel bases. I used to build stuff this way and believe me all these methods are time consuming.
Kevin
EOC_Jason
Bentonville, AR
FYI, I just re-uploaded the Prentiss file. I grabbed the book from Google Books and re-extracted the pages. So instead of a 3-4MB file it's like 577k (and better quality)...
If there are any problems downloading the PDF's please let me know.
methomas70
Chicago burbs
Picked up this cool "art deco" Wilton at a garage sale.
Two bucks.
Mark in Indiana
Southern Indiana
I finally finished my American Scale #75 pivot jaw vise. Please see pictures below. I'm quite pleased on how it turned out. In fact, I'm really having a hard time with the idea of selling it (my original intention). Well, on the the next projects.
BTW: Sorry the pictures are a little goofy. Had trouble transferring pictures.
bigcaddy
Orange County/ San Fernando Valley
Looks nice!! I'm still waiting for my American Scale to be dropped off by a friend of mine. I've never got my hands on one before and i really want to start tearing it down.
Nice Resto:beer:
bigcaddy
Thank you. I think that you will be impressed on how beefy those AS vises are.
I'm already somewhat familiar with it. I saw the vise in a picture at a particular sale near my friends house. All of the pictures were taken at crappy angles and didn't allow me to come up with a manufacture. I almost went crazy trying to identify the obviously stout little vise so i had him go by that afternoon and pick it up. Amazing enough it was still there hours later.
Hopefully i'll see him this weekend and can post some pics on here.
Maclin
Denver
Very Very Nice Beef. Beautiful job.
demoman
North Central Kansas
Outstanding info on the Reeds and prentiss vises. Thanks Jason and bl00
Mark in Indiana
Southern Indiana
Thank you. In the shop that I work in, I showed pictures to some of the mechanics. first the reaction was "nice vise". When they saw the pivot jaw picture, it was an OMG reaction. most of the guys (between 30 & 50) had never seen one.
