mr heater/big maxx
dipper
Rochester, NY
pretty sure it's only ~50 for shipping so you'd be better off getting it through northerntool. You'd save about 60 bux or more depending on the taxes (if applicable).
Is the vent kit available locally, cause it's availbable from northern as well and is a good deal. I doubt you can get all the stuff in the vent kit cheaper.
tfi racing
Cedar,BC
Don't forget the evil exchange rate right now,as well as the horrendous brokerage charge($100-120.00) if shipped UPS!.389x1.30=$505.70!+shipping,handling,brokerage,GST.You might want to get it locally...
scokat916
I think you can save 30% by using Microsoft live search and ebay. I thought one of the ebay vendors was Northern Tool.
dipper
Rochester, NY
yep, didn't see that he was in canada. that could make it a bit more. either way, it's a good heater.
blairtruck
Edmonton, Alberta
get it locally. i got mine at princess auto for 499.
i wont order anything from the US if its shipped UPS. to random of a charge when it gets to your door. could be 50 could be 200 who knows.
MonteIA
I found your thread while I was searching to see if anyone else has had as many problems with their Mr. Heater. I installed my garage heater, MHU45, in Jan. of '07 and have had nothing but problems and downtime. I've also found the customer service has little to desire. The circuit board had to be replaced right away. The heater would not ignite and after several attempts, got through to customer service to get the board sent to me (covered under the one year warranty). Still, the heater would only work if the cover was kept off. Then the fan blade broke away from the collar piece it attaches to. This time I could not get customer service to help me (transferred from dept. to dept., had to leave voicemails, and never did get a response). Then my warranty expired. Currently, it won't ignite, again. I truly regret buying a Mr. Heater hanging furnace. These should be good heaters (the competitors have great reputations: Reznor, Hot Dawg, Beacon Morris), but the parts are obviously inferior. BUYER BEWARE!!!
tim096
I have a mr heater 75,000 btu. Monte sounds like you have very bad luck. My heater is working great 2 years now. I have had no problems. I would also but a another one. the reznor is top of the line b ut also 2 times the cost. I live in buffalo and keep my garage at 60 doiring the winter.
rcleaver
Fairfax Station VA
Many states have lemon laws. That might help in this case. Contact the consumer department of your state attorney general (if you're in the US that is).
Chetter
Northern Ohio
I have the 45000 btu LP version of this heater and love it. Sounds as though the one gentleman got a bad one but in my dealings with their tech people was better than his and they were very nice and helpful. Like anything else, there are bad ones that get through the factory, that goes for anything you buy. I got their exhaust kit and used a Honeywell t-stat that I took out of my house and put in the garage for my furnace and everything works perfect.
fireman
I've had my Mr Heater 75K for over 3 years. It has worked flawlessly. I have 2 friends with them as well. No problems there either. If mine dies, I'll buy another. They are a great heater.
Jim
Hobby Man
Kansas
I am thinking about one of these heaters. My problem is I don't have a gas line to my shop. Does anyone use or know if you could run this off of a 100lb propane bottle?
dropride
NH
I have the modine version of this and am going to be using a 100# tank at least for this winter.
Hobby Man
Kansas
I know they are more expensive but do you feel the modine version is better then the mr. heater.
Chetter
Northern Ohio
Yes you can, I am running 2 40lb tanks tied with a regulator to run 1 tank and then automatically switch to the full one so I could fill the empty one. Great heater!!
rinker1
Just wondering, is there a difference between gas and propane heaters or will they run on either one?
Shocker
Olympia, WA
They can usually be changed from one to the other depending on the manufacturer. But they are not built to run both. They need to be one or the other.
MonteIA
Well, after no response to the voicemail messages I left, I posted an email on the Enerco site. I received a phone call the very next business day. The gentleman was very appologetic and sent me a new fanblade assembly and circuit board. My heater is up and running again. The fanblade is much improved, but the relay in the board is same type and manufacturer. This is my third circuit board. I'm glad others have had better luck with their units and also glad for the help I received.
justoldernow
Central PA
Seems I've been having problems like MonteIA. I'm on my third heater here from NorthernTool. First 2 came all busted up, Northern Tool sent me new ones with no questions asked. The third came without a scratch so I mounted it to the ceiling and hooked it up but it won't fire up. It clicks and shows spark but won't fire. I called Mr Heater and they said its a circuit board problem, they sent me a new circuit board which I hooked up and still have the same problem. I called Mr Heater again and the man said he hated to say this but they've had a circuit biard problem and he thinks this one is bad too. They're sending me another.
I'm about ready to call Northen Tool for a refund if this next board doesn't work. It sure is a nice looking unit but winter will soon be over ( I hope) and I'll still be using my space heater.
Any suggestions on a different brand?
Thanks...
indyracer
Indiana
I installed my LP Mr. Heater last week and while waiting for the natural gas service to be installed I thought I would run it off my propane tank. Then I can install my conversion kit and connect to NG.
Anyway, I had the same experience. The exhaust fan would come on and then the igniter would start sparking but no flame. After several tries thinking there was air in the line, I changed the regulator on my tank and it fired right up. Kind of strange, but it now works.
Tony
