Illini Pete
Hey Guys,
I recently purchased an 80 gal, 175 psi max, 2 stage IR compressor and am in the process of plumbing the air lines. I want to install a regulator at the compressor to reduce the pressure below 175 psi so that I can use various filters and other accessories that are rated at something below 175 psi. My dumb question is do I have to use a regulator that is rated at 175 psi or greater or can I use a regulator and gauge that is rated at say 150 psi? What I'm asking is if I were to install a regulator/gauge rated at 150 psi would it blow when I turned on the compressor or can it reduce the 175 psi incoming pressure to 150 psi max outgoing?
Thanks!
Pete
Thanks!
Pete
