The Harbor Freight PASS/FAIL Thread...
Rider_996
I like the idea of this thread as well. I'm planning a trip soon and would like to make a list. So far, urethane jack pad and dead blow.
My contribution is the right angle die grinder:
PASS- I use this ALOT and it works great.
Had the housing split open on me while installing an air fitting, didn't get very tight very tight. FAIL
Breen11
Can you quantify all of that? Some of your fails I would consider a pass and vice versa for the passes.
Everybody has their own experiences on things. I was listing mine. All MY Fail items & Pass items are based on numerous uses overtime.
IONH
Central Massachusetts
I get it. Free is free. I dont want them even if theyre free. Id have no use for them. But using them often they will fail @ some point. I had 2 sets that rounded out on me.
So what exactly failed on your screw drivers? I've used mine a lot and haven't had any problems. They didn't strip.
They are my go-to over my Craftsman or Stanley screw drivers as I would rather destroy free ones over the ones I paid for. That said, they get a lot of use.
Breen11
Thats just it. The tips round out (soft metal). I replaced them with a 2nd set & those ended doing the samething at some point. For the projects that I used them with, they failed me.
Brownsfan
Cleveland Ohio
I read through a lot of this thead and have noticed something. If someone fails a product they get jumped on and are asked to prove the failure. If someone says pass the response is great thanks I will take 3. People say snap on has fan boys and defenders that think it can't break or fail. But say HF pliers are junk(they are) and you are jumped on. Ask yourself this. If the tools were so good would there be a need for a pass fail thread? I have yet to see a SO or hell even a craftsman pass fail thread. Why? Not trying to knock any HF tool users here(I own some) this is just an observation I had while reading through. Oh and my pass for the thread is the pneumatic wire crimper. Does very good on larger gauge wire terminals(4awg 0awg etc).
cheechi
Triad, NC
Brownsfan, I completely understand where you're coming from. Nothing is good just because of the name, or bad just because of the name. Proving something is good or bad is what this is intended for.
But
Your example of the pliers, I will grant you they aren't as nice as my channellocks, knipex, or even kobalts. I will not agree they're ****. I got the hose pliers and while I can't say they're beautiful, they are functional and I have no issues with them. I had a rubber grommet to install on my brake pedal yesterday, have limited visibility, range of motion, in general its an awkward everything involved. This was the tool that succeeded where others couldn't. Taking off the fuel line from my pump to replace it, I have done it twice, once with just a pick & regular pliers and once with these, night & day difference. They are a pass to me.
I could easily ask you to prove to me why these pliers are junk. But in the same spirit of your post, making that generalization about HF pliers was just as bad as what you're complaining about.
I totally agree there should be a craftsman pass/fail thread. You should get it started.
Brownsfan
Cleveland Ohio
I didn't really go into my first hand expieriance with the pliers because I would have had 10 people tell me I was crazy they are awesome. I had some t&g pliers and cutters. They were complete junk. Got really rusty fast stored in the same box next to channellock. The t&g would twist under load and the cutters got very dull very fast. I do not own much HF at all and don't plan on adding anymore anytime soon. I buy the best I can afford when I need something. I am lucky I guess to be able to afford better than HF when I need to buy something. I feel like I can't get the smell off of me when I leave the place
fourtythree
WV
If someone lists a tool as a pass, you can pretty much assume the tool worked as it was supposed to. If someone simply lists it as a fail and gives no other description, there's a lot of information left to fill in the blanks. Why did it fail? How did it fail? Did a small piece of chrome flake off? Did it burst into flames? Simply saying "fail" and nothing else is an unacceptable way to review a product. Thats why people are getting jumped on, especially when they are tools that others have had success with.
cheechi
Triad, NC
Right, because the way you use something when it failed you might be different than how I intend to use it.
Same thing with a pass, if it's only a pass after you mod it, and you share how or what you did, then conditionally passing something with useful info is worth knowing.
I completely agree with you about the HF cutters, they dull fast.
Breen11
As most already know, HFT are a hit & miss anyways. Youll learn whats good, whats bad based on your own findings from using HFT. It just easier to write "pass" or "fail" then to go into great detail as to why.
If anybody really wants to why something got the "pass" or "fail" on any item, I dont mind sharing MY experience on the item(s) in question. I just (at the time) didnt feel like writing out all that info as to why something got the "pass" & "fail."
fsdogwood
RTP, NC
I do know what soft screw drivers are. Bought a Black-Friday set from Lowes
years ago, the brand was Stanley. The drivers acted like noodle, cooked, the
shaft twists, but not the screw that I was trying to drive.
On the other hand, even the HF screw driver set that you can get for free (the black handled ) would drive screws, when using manually, they (the Phillips ones) would ruin the screw, but the screw drivers were fine.
Please note that I don't want to say HF is selling quality stuff, nothing bad.
Instead, it's much valuable for all of us to report back and share our HF
tool experience. It will be more helpful for one to simply put the item
number and what failed when reporting back.
I've bought the cheap HF 1/2" impact wrench, that I'll label as fail, 95310 , had to return it, as it won't loose the
lug nuts from a Honda (80 lb-ft spec.). One might be able to make it work
but I am lacking the skill, so picked up a better one.
soloz2
Western NY
I've seen a few good reviews on the new gray colored floor jacks. Does anyone have the 2ton or 2.5 ton low profile jacks? My 3 ton isn't low enough to fit under my car without putting it on ramps first and yesterday after loading it I was unable to release it until I drilled a hole in the handle and inserted a large screwdriver for leverage. Are the newer jacks better or should I look elsewhere?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
fourtythree
WV
I have the 2.5 ton low profile. I love it. I've been using it for almost a year and its been flawless.
TAMPAGT07
Palm Harbor, Fl
djdaredevil
GH Michigan
I have the 2.5 ton steel and the 3 ton aluminum and they are both awesome
jacks, neither has had a problem right out of the box.
CarCar
East Texas
I have 2 of the new grey 2ton #68050 low profile jacks. 2 5/8" low to 23 3/4" high lift. They easily fit under my lowered Z4. I have 1 of the previous orange 2ton low profile 24" lift and 1 of the 2.5ton 20" lift orange jacks. The newer design are much improved with padded handle, foot pedal to raise jack platform quickly without needing to pump handle. Hydrauliks are strong and seem to pump quicker than previous design.
I give them a huge Pass.
soloz2
Western NY
I stopped at pep boys this morning and looked at the torin jacks, they look exactly the same as the old orange hf jacks. I have a 3t hf service jack. I also stopped at Napa hoping to look at what they had, but they didn't have a single unit I in stock. Just left hf. The new jacks do look quite a bit better than the orange ones. I left with a 2t low profile jack I was tempted to get the extended warranty but passed. What is everyone's opinion on the warranty?
the1nonlyjl
Westchester County, NY
if someone lists a tool as a pass, you can pretty much assume the tool worked as it was supposed to. If someone simply lists it as a fail and gives no other description, there's a lot of information left to fill in the blanks. Why did it fail? How did it fail? Did a small piece of chrome flake off? Did it burst into flames? Simply saying "fail" and nothing else is an unacceptable way to review a product. Thats why people are getting jumped on, especially when they are tools that others have had success with.
YUPPPPP!!!!! Gooooood pt made here!
Mandres
The plastic quick-clamps really do ****, but I just wanted to re-iterate that the HF blue F-clamps are a great value. Every time I go in I pick up a couple more in different sizes. I use them every weekend in the woodshop and I've never had a single problem with any of them.
They cost 1/5 of what Jorgensen or other brand-name clamps cost and they work just as well.
http://www.harborfreight.com/12-inch-bar-clamp-96214.html
pettybird
Cleveland OH
...Why did it fail? How did it fail? Did it burst into flames?...
I bought one of their butane pencil torches a few years ago, and yes that's exactly what happened!
The O ring at the twist-to-shut point failed, and it flamed away in my driveway where I threw it.
I probably got a dud, but it's funny that you brought that up!
ietech
East Sacramento California
big time fail on these clamps - did not last even one day helping to hold down wood flooring sections on a workbench while I cut a pattern with a jig saw.
http://www.harborfreight.com/12-inch-ratchet-bar-clamp-spreader-46807.html
I agree these are a "HUGE FAIL" I bough 3 sets at the same time and only about half of them can even be tightened enough to hold much of anything. The other half work fine.
I know yours is not the sets I speak of but the sets are identical to your 12"
TAMPAGT07
Palm Harbor, Fl
Used my new-to-me HF Earthquake impact today for the first time..(Bought it at a pawn shop for $25, in mint condition.) Worked like a champ.....Passaroni....
IONH
My about 8 year old MIG/Flux core wire 120 amp welder seems to have finally crapped out on me. Still spools the wire but doesn't spark. I reseated the polarity cables, still didn't work.
I don't think they even sell one like that anymore. It lasted me many spools of wire so I can't complain.
outdoorsman310
DE
absolutelybillsmood
Pennsylvania
The tongue and groove ones are junk but, I like my other HF pliers
iroc409
Thanks, I'll have to try some of these as I've looked at them a couple times. Since I'm just starting out with wood, my clamp collection is pitiful. I have some orange HF ones, and though I've used them plenty they are a pain in the rear.
Barnuba
Spring Grove, PA
Airless Sprayer Item# 60600
**PASS**
I've had this sprayer for 6 months now and have used it multiple times
-Sprayed finished basement walls/ceiling - 10 gallons
-Rolled basement with roller attachment (Graco attachment) - 4 gallons
-Sprayed all trim/doors for basement - 4 gallons
-Sprayed concrete foundation - 4 gallons
-Sprayed garage ceiling/walls - 8 gallons
I store this unit with pump armour and it has worked flawlessly.
mrg7243
50 foot 14 gauge extension cord. Item#41447
Fail
I was using it attached to my blower, got alittle to far out and when it unplugged from the outlet the ground ****** sheared right off.
yogitech
Orlando, FL
I have this set and used it once. It worked fine. I've used the spacers for pounding other things out. Nice to have. Everyone says to make sure to grease up the threaded rod so you don't gall the threads.
I use mine with an impact at least 3-4 times a week, after 3yrs I finally sheared the head off the bolt. Lol I was actually surprised it lasted that long. I welded another bigger/ stronger nut to the threaded rod and keep hammering away. Been like that for the past 20 uses or so... No issues thus far!:thumbup:
