Under slab insulation source
Flexia
Akron/Canton Ohio
I have been trying to price out insulation for my slab. I cab only find it at the box stores and is about $30 a sheet. Where did you guys source it if not from HD, Lowes? I have tried a lot of local construction yards and they don't carry it
Sent from my SCH-I605 using Tapatalk 4
Highbeam
Mt Rainier foothills, WA
The factory. You're ordering a decent amount. I got 25 psi 2" foam made for me and it was of course cheaper than the home depot.
You seem price sensitive, surely you are not thinking that you must pay double for the pink or blue? You can use white too.
F
Flexia
Akron/Canton Ohio
Im not really price sensitive, I just know it can be purchased cheaper. And as in white your talking about eps correct? Cant seem tofind that around here for underslab use either. Where did you find a factory at Highbeam?
Highbeam
Yes, white EPS Is rated for underslab use. There is an insulfoam factory in Kent, WA. They puff the beads into board.
The plant has now moved to Frederickson where they also make polyiso board.
Doesn't your home depot sell eps? Why don't you think that is for underslab?
F
Flexia
Akron/Canton Ohio
The eps I have found doesnt list under slab. And is only rated at 1lbs denisty and I dont think I want that under my slab.
HoosierBuddy
Southern Indiana
I bought mine from the same concrete company I bought my wire mesh and concrete from. It was dow brand and rated for underslab use.
That was 2006. No cracks.
Phil
Highbeam
Look again, 1 lb density foam is not rated at 1 psi compressive strength. You'll need to call the manufacturer and ask them to decipher the specifications.
F
Flexia
Akron/Canton Ohio
I do understand that. From what I have found its about a 12psi rating. Still waiting to hear back from the manufacture though
Highbeam
The HD stuff should be a 15 psi board, you can buy 25 psi if that makes you feel better but realize that 15 psi is stronger than the ground under it in most cases and even 6" concrete only weight 0.5 psi.
dieselgarage
Menard with the 11% rebate was the best deal I could find. bought 4000Sq feet this spring.
rburke65
Canfield, Ohio
Go to Craigs list, and you will find, in Akron, a guy selling the insulation. Very reasonable prices in my opinion.
bfarroo
Green Bay WI
I've seen the 25 psi stuff at Menards for 26. Thats the cheapest I've seen at the box stores. I contacted a local manufacturer of EPS and they gave me a price of $20 for 25PSI and 15 for 15PSI. I'd do a little research and see if you can find a manufacturer of the stuff in your area. The only downfall is they have minimum orders so you can't go buy a few sheets so you need to make sure you figure out your order correctly or get a few extra sheets just in case. I'm getting a mixture of both I'm going to use the 15 around the outside and the 25 everywhere else. If it was only a dollar difference between the two like it typically is at the box store I'd do 25 on everything but saving 5 bucks a sheet I'll use the 15 where it doesn't matter.
F
Flexia
Akron/Canton Ohio
Ok I seem to have found 1inch board cheap. Is it ok to layer them underslab to have 2inch total?
F
Flexia
Akron/Canton Ohio
I guess its 2x4 sheets that are tongue and Grove. He didnt put that in the listing. Think that would be risky layering that under a slab?
StupidSheet
Lorette, Manitoba
That's what I ended up using. Found someone selling it cheap. $8 a sheet. :)
