mohawk finally in action
JimVonBaden
Northern Virginia
well, keeping my fingers crossed.
Definately want to find some tall screw style jack stands to take out the fore and aft rocking though. I know I'd feel better.
Nice!
Jim :cool:
avc8130
Looks great! I see you chose to lay right over a control joint in the floor?
ac
W
Wheelgun1
AVC, yes, I had no choice, had to split the difference. It's not a true all the way thru control joint though, so I'm pretty confidant. Do you get much fore/aft rocking with any of the vehicles you've lifted so far?
Krash, thanks for the compliment, more people DONT know what it is than do. It's actually a true J-code Cobra
I'm having no luck finding a screw type assembly that I can use to weld up some under lift supports.
avc8130
That's why they call it a "control" joint and not an expansion joint. What you have is basically just a saw cut in the slab part way. That way, when it cracks, it cracks or stops there.
I've only had 2 vehicles up on my lift:
1. Volkswagen GTi. This thing was like a go cart. I'm pretty sure I heard the 9k System 1A laughing when I pulled it between the posts. It was rock solid stable.
2. Chevrolet 2500HD CCSB Diesel. It took me a fair bit of fiddling to get the truck/arm placement to where it lifted smoothly and evenly. When the truck is on there, you can definitely get some oscillation going if you lift up or push down on the back of the truck.
How about you? I tried finding information about your lift, but I can't find squat. What did you wind up paying for it? Have you spoken to Mohawk about it at all?
ac
Mike in Ohio
Canton,Ohio
http://i165.photobucket.com/albums/u63/BlueOvalDave/daveiphone2137_zps65e1cf6b.jpg
http://i165.photobucket.com/albums/u63/BlueOvalDave/daveiphone2138_zps61acb2a3.jpg
What year torino and truck both of mine are '69s. Now I really need a lift.
Look at the home improvement stores for jack posts they are used in my area to support beams in basements. you will have to weld on a bigger baseplate though as the bottoms are usually set in concrete in a house.
W
Wheelgun1
it's an older unit from the mid eighties, they had a system one (heavier lifting capacity 7,000 lbs i think) and the little brother system two.
I paid $800.00
gnxtc2
New york
I got the tall jacks from Greg Smith.
Congrats on the lift. You'll be amased how you did w/o for so many years. You'll never want to work on your back. You'll be lifting the cars up just to wax the sides.
Billy T.
[email protected]
W
Wheelgun1
70 Torino, 67 F-100 with a 98 mark viii driveline, 2005 crown vic squad car front clip. I was at home depot today, no luck. Going to try Tractor supply
Thanks for the compliments, but when my garage grows up it wants to be a real shop like Billy's. Nice set up sir, and very clean. Whats under the car cover if I may be so bold?
W
Wheelgun1
very nice! single turbo? my neighbors BIL has one set up for strictly strip as well. It's amazing the horsepower they can generate. Push out many head gaskets?
Shadowdog500
Down the shore
Looks great!!!:beer:
As you pointed out in another thread, Your back will be thanking you!
Now you need to get the other toys that go with a lift.
Tall jack stands
Roll around oil drain
Trans jack
Work cart to put your tools on when under a car.(I use HF 4 drawer cart)
Slap some magnetic bowls on the columns, I put them on the arms to hold lug nuts when doing wheels.
Believe me, they all come in handy.
Chris
avc8130
Tall jack stands
Trans jack
Chris
I've noticed I need those things also. It's starting to seem like the lift was the "cheap" part!
ac
Mike in Ohio
Canton,Ohio
Do you have a build thread on the truck on Ford truck enthusiast forum? I seem to remember seeing something like that over there but I don't spend a lot of time over there.
W
Wheelgun1
I did have one on Fordifications but it had a stroked small block in it at that time
Mike in Ohio
Canton,Ohio
My 69 is a frankentruck or a mutt as I call it. Almost nothing original, I bought it in '06. It had a 75 gallon semi truck fuel tank mounted in the bed, and plumbed into the fuel system. The frame and running gear is the heavy duty 3/4 ton with the larger brakes, the body (or at least the front fenders and drivers door) are half ton. The vin number is on the drivers door on these old trucks. It has intermittent wipers (not available till '78 I think), a 460, (not available until '75 I think) aftermarket air conditioning made to match the contours of the dashboard. A very uncomfortable aftermarket seat, and the source of my most recent headaches the tilt/telescoping steering column out of a 66 Cadillac.
