what else are drag link sockets used for?
carterbeauford
NW PA
I thought I had every tool I'd ever need until I found that John Deere in the 1950s used drain plugs on their power steering with a 1 inch wide slot in them. they use similar bolts to hold the floor pan onto the tractor I am restoring. what are some other common applications for this tool?
gatewaysysop
Arizona
I used one for a rather unorthodox application, removing the collar bolts from an 8" Parker vise because I didn't have any standard bit sockets that were even close to large enough. Worked like a charm! :thumbup:
crewchief888
NW indiana
you'll find some holding the front cover plate onto many JD engine blocks.
:beer:
rusty65
Pekin,IL
On certain drum brakes if I'm not mistaken.
Sent From Snap On Headquarters deep in China.
Murphy4570
West Deptford NJ
I have one of those, ancient Plomb 1/2" drive one from my grandfather's toolbox. I have never used it.
Must be agricultural and ancient mechanical use only. I have never come across any need for it in automotive.
Old cars up to about the 40's and 50's used them for...
Wait for it....
Drag link adjustments.
I find use for them every so often, the last time was for the pivot screw on a vise swivel base.
monkeyspanners
Oxford, UK
The older Fabdec bulk milk coolers have the agitator mounting plate held on with big whitworth screws that need such a tool. Just invested in a Gedore one.
KinzeMech
x20 series?
mech-tech
Older clark forklift steering linkages...older tractor steering gear box lash adjustment
TDLMOMOWERS
Used them all the time when I worked as an industrial truck mechanic. Mainly used on steering linkages. I have 3 different sizes. Since retirement, I have used them on Model A Ford steering linkage.
