Lubricating ratchets
kams1973
Amarillo, TX
MMO, Motor Oil, 3-in-one, wd-40, ****** fluid, RLL, Super Lube, Vaseline, Brake Caliper Grease, Never Seize, Kopper Kote, Wheel bearing grease, etc, etc...
Pick your poison.
Fedwrench
Valley of the sun
Pick your poison.
Absolutely!!!:+1:
Some like blondes, others brunettes, still others prefer red heads:dunno:
Ratchet lube is a personal choice. The only thing I can offer is fine tooth= thin lube and coarse tooth (36 and under)= thicker lube.
CWP1616L
USA
Snap-on 30 tooth and 36 tooth ratchets = Superlube
MAC 30 tooth ratchets = RLL
Cornwell 36 tooth ratchets = Green Permatex
They all like their own lubes.
priceman1414
Midwest, USA
When I decided to lube my Craftsman ratchets, I found a pdf online of the instructions for a rebuild kit, said to use SAE 30 weight oil, but I used 50 weight, worked good but some of the oil seeped out, though I put in way more than the four drops the instructions called for.
TwoInch
NW INDIANA
Lithium or Petroleum grease?
lithium grease is petroleum grease....
lithium is the soap, which is a thickener, oil is the lubricant in a lithium grease.
there are many soaps used in greases, calcium, lithium, sodium, etc...
as for a ratchet, lithium soap grease is not a good choice really for any ratchet style.
some of the best choices for ratchets are superlube for coarser mechanism, permatex assembly lube for coarse and fine mechanisms, and heavy oils like 50wt or similar for fine mechanisms.
some people claim to use silicone brake greases, but i advise against it. they are not proper lubricants for mechanisms like ratchets or loaded gears in general. totally different style of lubrication for very different types of material contact.
woody 73
The Great State Up North
Over these many years I have used everything but I always keep coming back to the same product from HF called super lube $4.99 per tube.
By mistake I used one of the white soap/grease products years ago and that soap just turned to cement but the super lube has never failed day in and day out.
The red lube of love runs forever good stuff but very messy.
Hope that helps you out.
Outlander
Quebec, Canada
Super Lube used to be available at Canadian Tire, but it does not seem to be carried any longer. Need another road trip to the US, I guess :) I have been using motor oil, air tool oil and bike chain oil.
I may regret any or all of those when it gets cold here next winter!
TwoInch
NW INDIANA
you can get superlube from a few sources. i believe a GM dealership carry it branded under GM
GM P/N 12371287
check your local GM dealer.
jakemac
New England
I've seen it at Ace and True Value hardware stores as well. Not all TV's carry the same stock, try looking at a few.
Edit - I just noticed the the OP is in QP, Canada, I haven't been to St. George in a while (no passport), I'm no longer familiar with the stores in the area. Try the NAPA, or hardware stores in Jackman, ME if you head south.
Outlander
Quebec, Canada
Did not try NAPA, I have a couple near me I use. :thumbup:
Outlander
Quebec, Canada
GM P/N 12371287
Would look,like this I guess
from Amazon
mrg7243
How much grease should you put in? I pretty much packed my craftsmans with as much as I could. One had lithium grease, the other had moly. The one with the lithuim is louder but feels firmer with the clicks. The moly sounds sloppy, and squishy.
Tarheelgarage
NC
You really need to get it packed as full as possible .
I recommend you also use a wheel bearing grease packer to ensure you get it full.
mrg7243
Well I packed it so full that it was oozing out of the buttom and lever hole.
Sent from my SCH-I535 using Tapatalk 4
reptilezs
where you buying your Krytox from. I found a syringe of it in a bike shop 3 years ago and i haven't been able to find it since :mad:
almost any bike shop can order it. it is marked up a little bit though. it is branded by finish line
jmm
NC
Really depends on the ratchet, but if you only want ONE lube, I'd go with superlube.
I also use Deep Creep, Assembly Lube, ATF, gear oil, and God knows what else over the years.
