I bought another Hot Tank, Jet Spray this time. I am going to keep my Soak type for using Caustic Soda for use with Cast Iron. I've had the soak tank for about 4 yrs.
I doubt very much that I will ever " have to " run both machine at the same time, but if the situation came up it would sure be nice. I ran 8ga. wire on a 20 amp breaker for the existing circuit
I have plywood on the walls and it will be a PIA to remove to run a complete new circuit. Other option is to tie into my existing outlet and add another outlet 4'-5' away. Runnin both machines at the same time would be doubtful.
Both machines can be run w/o heat and just circulating the cleaning chemicals.
__________________________________________
Pros of adding a new circuit - the few times a year I would want to run both machines, I could.
Cons ... PIA, have to take down my " Head Working " Bench and remove all the plywood. But could be done in a day.
Pro's of tying into the existing outlet, ... easier to do
Cons, doubt I could run both units at one time.
______________________________________________
Whats your opinion ?
TIA
TIA
