impact sockets vs regular sockets
MechMyk
Utah
I was thinking about this the other day when reaching into my tool box looking for a certain socket. I passed over my ATD impact sockets several times trying to find this chrome socket. Then I realized why not just use an impact socket. So I did and it worked just fine. Then I started thinking why don't people just skip the chromes all together? Aside from being slightly bigger and less pretty I honestly can't figure out why we have chrome sockets. Impacts are much stronger and aren't as slippery when greasy.
bonneyman
Desert SW
Some people like the look of chrome. Plus, it rusts less. And some people prefer 12 point sockets - impacts only come in 6 point.
On some applications, the thicker wall of an impact would prevent it's use. But, one can use impact sockets both ways, whereas you can't use chrome sockets with impact tools and get away with it for long.
CWP1616L
USA
Chrome sockets have a smaller outside diameter from being thinner to get you in to tight spaces.
Nick6
Impact sockets can be had in 12 point too.
ChevyEFI
Phoenix, AZ
:headscrat
CWP1616L
USA
Looking at that snap-on socket, I wonder if it was a coincidence that snap-on has their writing upside down to coincide with Hansen trays holding the sockets upside down. With the snap-on socket being upside down in a Hansen tray, you'd be able to see the size on the socket right side up.
andre_saltiva
Actually impact socket is softer than regular socket.it will come wear off more sooner than regular one.
shoggoth80
Seattle
I could be wrong, but the different steel used in making the impact... does that make it more likely to deform vs. shatter outright?
Alfajuj
Taiwan
BTW I've got a Koken 12 point impact. It's a real impact socket. It's not a hand socket with industrial finish.
The steel used and the heat treatment in impact sockets is different to give flexibility toughness so they won't shatter, but they do wear faster. I think they are never chrome because the flexibility of the material under stress would let the chrome flake off.
The impact sockets used in factory applications need to be replaced as often as once a month in some situations.
Using a hand socket on an impact tool may not just shatter the socket or flake the chrome, it can also damage the impact tool's internal parts as well.
But I see no compelling reason why it would be bad to use impact sockets on a hand ratchet. It might be clumsy and not fit in some places, though.
Using chrome sockets on an air ratchet wouldn't do any harm, either.
If you're really going to lean on a fastener and for some reason you can't use an air impact wrench, you need to use a breaker bar or T handle with a cheater bar (shh...don't tell anybody) it would be much better to use an impact socket in that case.
rodm1
I do (1/2 drive) and I can't think of any time I needed chrome. With a 3/8 drive you probably would run into clearance problems.
I have so many sockets if I had to start over I would like to try impact for SAE and Chrome for Metric just to keep them organized better.
fnieto
Tucson,Arizona
As stated, impact sockets are softer therefor not recommended for critical torquing (head bolts etc).
And chrome quality sockets would crack over time when used with impact.
So you still need both types if you consider yourself a pro.(please, no offense)
wafrederick
Holton,Mi
I have a set of Matco shallow 12 point metric impact sockets,including a 9/16 and 1/2 which I do use.I use the 9/16 on 1994 to 2001 Dodge Ram 4x4 wheelbearing retaining bolts.Will go through anvils too if using chrome sockets and attachments a lot.Does damage to the impact also.
Zeroek
Indiana
I remember seeing Gray Pneumatic selling 12 point impact sockets. I try to have both in my box. The guy that works next to me uses all impact sockets and barely owns anything chrome besides I think his 1/4" stuff which is fine as long as it works for you but when you like tools so much you just can't go wrong with having it all.
firebox40dash5
I guess all black tools are for impact:headscrat Without looking at # it might be industrial finish
I can assure you that you can buy 12 point impact sockets, regardless of whether the ones pictured above are impact or just industrial finish.
I use my impact sockets most of the time, on both impacts and ratchets. My 3/8" chromes all look nearly new, and the only time I've used a 1/2" was to chop it down for an Ecotec oil filter sockets. Can't say it's ever posed a problem besides clearance... in addition to being thicker they're usually deeper in a given length than a chrome from the same brand. Hell, all my random 12 points for doing unit bearings and head bolts are impacts too- they stand up to a few hundred ft/lb on an impact, never had a problem torquing by hand with them.
01ps
Grey tools makes sockets that are supposed to do both with slightly thinner walls but capable of using with an impact. I thought about them for 3/8 drive just to save space but didn't pull the trigger. I think they are duo sockets?
MLB0611
My mainly used drive size is 3/8th and 99% of the time I use impact sockets, I have chrome and they sit in my box, I cannot remember the last time I had to use a chrome socket because my impacts would not fit, my impacts are snappy or matco, shallow, semi-deep and deep.
1/2 is the same the last time I used a chrome socket was because I did not have a impact that size 30mm 12 point.
1/4 is the only size I only have chrome only, My advise to any tech coming into this biz is if you are buying HF/craftsman etc, buy both because the impacts are way thicker, but if buying snappy, just buy impacts, they are cheaper than chrome snappy's and much more useful.
As for not using them with a torque wrench, I call BS, no were have I read not to use impact sockets with a torque wrench, extensions and adapters yes but never impact sockets
bonneyman
Desert SW
Guess I was wrong about 12 point impacts.
I've never seen one in the flesh, and, when I asked once if companies made impacts in 12 point, the two mechanics looked at me like I was an idiot and said the points are too small on 12 points to take the abuse of impact use.
exophyusical
Pretty sure this is false, my local bumper to bumper has a set of 12pt Sunex impact sockets, not sure what you'd want them for though.
I turned a few of my impact sockets down on a lathe, these get used regularly and show no signs of breaking. Not sure that impact sockets need to be quite as beefy as many of them are.
ChevyEFI
Phoenix, AZ
:headscrat
I figured someone might do the due diligence of reviewing the image address and seeing the PN, which is enough assurance in any case.
http://buy1.snapon.com/catalog/objects_lg/images/IMDM270.jpg
Snap On IMDM270 27mm Shallow 12 Point Impact Socket
http://www.toolpan.com/assets/images/kok14305-30-Large.jpg
Koken 14305M-30 - 1/2" Drive Deep Impact Socket - 12-Point - 30 mm
4x4gearhead
New Hampshire
I myself actually had no chrome 1/2" sockets for a number of years, and for the most part I was fine, but every so often I would need the thinner wall to get in somewhere. Other than this reason I cant think of why you couldnt. (I know the thinner wall was mentioned but just wanted to share my experience.)
