OccupantRJ
Thanks for posting pictures. What size pipe are you using? I figure the more info everyone has the better. The only suggestion I have so far would be to add a union to your up and over drops (on the tee), then you can take it down to add to it or change something with ease. I was going to add valves to my trunk line, but now that I have played with it, I don't think they are needed. I just shut off the valve at the compressor and open one of the drain valves on a drop, it lets the air out of the piping system really quickly. I actually wish I had not put the valves at the top of my drops, I may move them. I figure the system is a living thing, at least in my shop, and it will evolve as I learn what works for me.
I have had workshops for so long that I have generally found out what works for me and what doesn't. There is pair of unions on each section to allow me to easily handle any modifications. I made up the sections on the floor, then hung them on the wall by myself by resting the piping on 3 inch deck screws driven in strategic places. I used a string line to set the pitch of the piping path, then used the screws as temporary resting points. The straps were then attached with no stressing involved. The screws will be removed later. The trunk line is 3/4 pipe, and the drops are both 1/2" and 3/4", depending on what they are feeding. After about 40 feet of run, the trunk will drop to 1/2", as It will have passed by my blasting cabinets by then. Each drop will have a condensate drain at it's lower end. System will be powered by two 5 hp Saylor Beall compressors with 80 gallon tanks piped in parallel.
I guess you don't believe in manufacturers recommendations either.
