MaxJax Lift: My Working Impressions
FoMoCo_Mofo
So Cal
Being one of the few people lucky enough to test the first production MaxJax lifts, I have much to talk about regarding this lift. I work on both motorcycles and cars, which are both old and new, so there are a myriad of different size and weight vehicles to test. I, like most of you also have a pretty limited space in which to do work. This is why I believe Jeff thought I would be a good beta tester, not to mention I am pretty local to Dannmar and have done some things with Bendpak and Ranger in the past.
When the lift was delivered it didn’t take long to install. I would say less than an hour to get it up and running. We decided to first mount in under the carport right in front of the garage entrance in my driveway. Once we figured out exactly where we wanted it to go, we made our measurements, checked them twice and drilled the concrete to check the true thickness. Once the concrete was determined to be up to snuff it was as simple as marking the other holes and drilling the rest of them. From there we tapped in the drop-in anchors and tightened them all up with a 12v impact. We then broke out our level and got everything straight with the shims that came with the lift.
From there we slid on the lift arms and attached the hydraulic lines from the power unit to the lift and plugged the unit into the garage’s 110 wall socket. The lift fired right up, and went up and down with easy. so we gave each other and two of the neighborhood rides on it until we drove my `59 T-Bird on to lift it.
It lifted that pig of a car right off the ground with no issues except that the Panther Creek carport above it is a bit short, so we didn’t get to test the full extension of the lift with a car. Don’t worry, a new tall custom constructed carport is on it’s way soon, so we’ll be able to have even the tallest cars at the lift’s height limit without hitting the roof.
We then put my `89 Harley-Davidson FLHS on it. The bike is pretty low, so we though this was going to be a bit of a chore. We pulled the bike up to the lift and slid the arms underneath the bike from the left side of the bike, then slid the motorcycle mount onto them underneath the bike from the right side without issue. We then pushed the up button and the bike was raised to a comfortable height to work on.
I have been using this lift with various cars and bikes for a few weeks now and have given Jeff and the staff at Dannmar a few things to think about. Nothing that has to do with the design or operation of the lift itself, but more facts regarding the various mounts that are being made or that could be made.
Things I like:
• The ease of use
• The size
• The portability
• The option to use it with either a car or motorcycle
Things that I feel could be improved:
• I personally would like a little more length in the hydro line. I work on some early and mid- sixties cars. They are LONG and almost come in contact with the power unit when pulling the car up to the lift.
• I would like to see a bit more length on the motorcycle mount so one does not have to maneuver the bike as close to the lift as you do now. 2.5” more length would do perfectly.
• For saftey’s sake, I would also like to see some tie strap “D” rings on the sides of motorcycle mount as well.
I will be getting more of the floor mounts in the coming weeks and will install it inside the garage, so stay tuned for that…
Here's a few Pics of the my H-D currently residing on it.
goodfellow
NoVA
That is great!! Thanks for posting !! I can't wait until they actually put these things out in mass production.
Junkman
Northeastern CT
I think that I am moving to California so I can become a beta tester... :lol_hitti
That sure looks nice ....... both the bike and the lift... :thumbup:
akdiesel
Wasilla, AK
Great write up on the lift.
A few ?'s. What was the thickness of the concrete you installed it on, how much torque did you use on the gun, and how heavy is your bike?
PAToyota
South Central Pennsylvania, USA
You know, I hadn't even thought of that possibility. Places like California you might be able to have a regular lift outside all the time. Around here it would get ugly fast through the winters. But in my situation with lower headroom in the garage, pouring a slab outside and moving the lift out there when I needed more headroom would be just the ticket in nicer weather!
Ok, I'm sold. Just one more thing that makes this the perfect setup for me. :thumbup:
F
FoMoCo_Mofo
So Cal
the thickness of the concrete was 6", the torque on the gun I didnt check to tell you the truth, it was a Craftsman# 19984 set to max.
The H-D weighs close to 800lbs fully dressed.
The T-bird we put on it weighs in at 3903lbs
F
FoMoCo_Mofo
So Cal
We actually are weather testing the unit. I spray it down with water and let it set on the lift every 3 days and have not cleaned it since it was installed (and it's driving me nuts since I am kind of a neat freak when it comes to tools)
I will also be letting y'all know how the wear and tear goes for the next 6-months or so.
motox88
So 6 anchors per post? How deep? Is the install any different from a std lift as far as anchoring?
F
FoMoCo_Mofo
So Cal
The anchors are about 5 inches long and yes, the anchors are of a bit different design as the standard lifts Dannmar sells.
F
FoMoCo_Mofo
So Cal
Whether it can take outdoor weather or not, being able to tuck it inside all safe and sound and bring it out when needed is just another selling point!
I am actually going to be buying one of these lifts when they are available for my place in Montana, so I'll be able to EASILY do some extreme weather testing up there!
Yes, I think that being able to pull it in & out of wet and cold conditions is one of the BEST selling points of this lift.
Junkman
Northeastern CT
When I talked to Jeff a few days ago, they were still working on the pricing. They are still working on developing the total costs of production, shipping, etc.
alberto
Looks like the bottom clearance is pretty high. Doesn't look like a sports car or hot rod can make it without ramps. What is the minimum clearance?
Also, it sounds like you have it fairly fixed in place and you are not removing it and putting it back in place. Do you plan to do that?
Thanks.
Alberto
Mr. E
Thanks.
Alberto
This video makes it look like sports cars are no problem and do not require any ramps.
http://www.maxjaxusa.com/maxjax-lifting-system/maxjax-video.html
F
FoMoCo_Mofo
So Cal
The photos I have posted do not show the lift at it's lowest setting.
My T-Bird is as low as a car could possibly be drivable with a static drop (no bags or hydros) and I have had Zero issues getting the arms under it.
F
FoMoCo_Mofo
So Cal
I have unbolted and moved it several times with no re-alignment issues. I did color code and weld the alignment spacers together to the right height per location, so it can quickly go back into the spot it was originally in.
427HISS
I've pointed this out with some other threads, I'm so excited about this lift for not only the price of $1,500, but it will help out tremendously in my single garage. I build a 1966 Ford 427 Shelby in 2000'. Wish I had the lift then !
The car is so low, that even with my friends larger lift at is mechanics shop, I have to drive up on 2x4' on all wheels to get the arms under the frame rails.
I have to do the same at home and,....take my low profile jack to lift the front up a few inches, then the back few inches, then the back, to the front again ect.... until I get it high enough to lay on my back. It's quite a job and takes a lot of time. THEN, reverse the process. Hell, by the time all this happens, I'm pood-out !
It will be great with the low 3.5" arms to simple swing under the arms and lift !
That's all. What a time & work saver.
Thanks for creating this lift guys. :thumbup:
This may show how low my Cobra is, even the side pipes.
ghlkal
Fredonia, WI
FoMoCo ... thanks for your initial thoughts.
Do you have more feedback now that you've lived it with for a while?
Thanks
danfromsyr
Cicero, NY
Funfer2, I use my car caster/positioning dollys to offer a quick lift to get the floor jack under. the car dollys I have are the hydraulic kind that lift the tires. they lift ~2" or such, usually enough and fairly easily to roll out. lift and not in the way of the floor jack..
I often forget the reverse, lower the jack... then can't get it out.. roll over the dolly and pump it up..
I'm very interested in this lift system for my multi location needs in my garage..
Dan in NY
427HISS
Hello Dan, I actually tried the dolly's with my Cobra and I did not care for them. I don't recall the brand but I'm sure they were not the best out there.
While building the cobra, I did buy a set of dolly's, the type that have a V bend, and have casters. My tires were too wide and would be on top the the bolts so, I made four 1/4" steel plates to lay on top, and it works ok but, I can't wait for the lift !
It will be great not to drive up on the 2x4's or jack up the car to use my dolly's. Just a simple oil change will be easy.
427HISS
Is this not the type you place under the tire and pump it up with your leg ?
427HISS
Mine look more heavy duty and, I made a flat plate since my tires are too wide to fit in the concaved part. I would have to take a pic of then for you to see. They are really nice.
F
FoMoCo_Mofo
So Cal
Thanks
I'll tell you, this lift is still tops on my list. I am in the middle of changing the interior of my garage. I am going to mount the posts parallel to one another as close to the back wall of my garage as I can. That way I can store and/or work on two motorcycles without taking up too much of the center of my garage.
This is what is great about this lift, the ways it can set it up and used are endless.
427HISS
That should not be an issue, as the arms are wide and stable. You may use a ratchet tie down for security assurance.
F
FoMoCo_Mofo
So Cal
I have only used a tie down when I was changing out the wheels on my `89 H-D as a precaution. I fastened them around the upper arms,looped around the frame of the bike and attached them to the center of the bike adaptor.
the bike did not move a millimeter...
thefirebuilds
Thanks
I have one of these in place at my shop in Racine if you are interested to see it.
To the rest: we are having some issue with the arms raising at different rates, is anyone else using this lift that can comment on that?
F
FoMoCo_Mofo
So Cal
I'll tell you guys I have been using it just about every weekend now that all the guys in my club know I have it.
It has been rock solid, even lifting real cars with steel bumpers!
